Question about Gateway FPD 1730 17 in. Flat Panel LCD Monitor
I normally leave my computer on when I go to work, when I get home the monitor LED light flashes when I move the mouse but the screen takes about 10 min to come on, my other monitor turns on right away. I have checked the power settings and still does this for about the last 2 weeks.
  • 11,361 Answers
You may have dying power supply due to bad DC filter caps, try this monitor with other PC first.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 23, 2010
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
LCD monitor not working right
This is 2004 model, it may not be worth putting money and time into repairing a 15" monitor. But you can at least look inside for any damaged, burnt components, lose connections, etc. otherwise to do a component level repair at the shop will not be worth it.
See eample of what usually goes wrong with LCD monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 05, 2010 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Power light flashes continually but monitor will not work. I leave computer on at all times but turn monitor off. I did that last night but today it was flashing and won't come on or off. I tried turning...
Yes. Flashing LED with no image on the screen is the first sign of the power supply gets overloaded. That may be caused by blown/shorted electrolytic capacitors. Open the monitor, take metal lid off and observe for those caps which are rounded on top. Replace them with proper ones.
Sep 11, 2009 | Acer AL1916W 19" LCD Monitor
After trying to change the resolution on my monitor to maximum screen resolution it has just gone blank. the start up menu works ok but then when desk top and start menus should come on the screen is...
Move the mouse so it is way, way down in the lower right corner. Place a penny or dime on the mousepad touching the upper left corner of the mouse. Pull the mouse diagonally down to the right a distance equal to the diameter of the coin. Then back up to the coin.
Right Click
Take your hand off the mouse because the rest is on the keyboard.
up <arrow>
<Enter>
hold <Shift> press <Tab>
right <Arrow> 10 times.
<Tab>
left <arrow> (decreases resolution, right arrow to increase)
<Enter>
By the by if you can find a monitor that will accept the resolution you selected on the 'Properties' window you can switch it back the normal way
Aug 04, 2009 | HP Pavilion F1523 15" LCD Monitor
My monitor screen goes black shortly after I turn it on.
if there is no LED light on monitor, put it to service, if it lights, try if OSD menu works, or try to push source button if you have it
Jul 10, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Dec 03, 2008 | Microsoft MNTR TYRIS|LCD 19' 8MS DVI...
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
