Question about Spectroniq PLTV3250 32 in. LCD TV
Was watching the televisions and it just went out. Unplugging it didn't reset it and the power cord is in pristine condition. Is the problem fixible?
  • 11,361 Answers
Power supply failure in this Spectroniq/Protron PLTV-3250 is very common. That will be the first place to check.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Posted on Aug 23, 2010
  • ami0797 Oct 15, 2010
    What do I do next???
  • Bud Martin
    Bud Martin Oct 15, 2010
    Take it to the reapir shop or buy the tools and learn how to go about fixing it as I indicated, you need to do the troubleshooting by first looking at the power supply filter caps, voltage checkings, etc. If you are not sure what you are doing , then leave it to the pro isnce we are dealing with high voltage that can kill you.
Blue light flashing continually - can't switch on
Many electronic devices today can be reset by unplugging the power cord and waiting 2 to 5 minutes and then plug the power cord back in.
Aug 25, 2013 | Hitachi 32LD8700 32 in. LCD Television
Hello, I have an LG Plasma tv, which went on stand-by as I was watching, I called LG and they told me that it needs resetting, please can you help me.
If by unplugging the set for a while and then plugging it back in did not fix, then you have either a bad Main board or Power supply. I would bet on the Main board.
Apr 04, 2011 | LG 42PX5D 42 in. Plasma HDTV
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 16, 2009 | Sanyo DP42746 42 in. Plasma Television
Sylvania SRT2232S Powers On, No Picture, High Frequency squeal
Hello there. I'm sorry to say that it sounds as if the element that actually energizes your screen is bad. It is most likely overheating. or quite poosible the power converter lost a resistor or 2.
Nov 27, 2008 | Sylvania SRT2232S 32" TV
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Power went off
Have you tried unplugging the receiver from the outlet to let the cpu reset?
Dec 29, 2007 | Sony STR-DE345 Receiver
Spectroniq PLTV3250 32 in. LCD TV Logo
153 people viewed this question
Top Spectroniq Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
