Question about Troy Bilt Tb70ss Gas Trimmer
How do i remove the outer assembly spool on a troy built gas trimmer tb575ss
If you are talking about the side where the clutch is, there is a Torx screw inside the hollow part of the clutch housing. Using a #20 Torx bit, loosen screw. If this is the first time on this screw it will be tight and the drive shaft will turn with it. You will have to remove top of cylinder head and put something soft inside the cylinder to stop piston from moving up and down; usually a towel and something stiff like a screwdriver to hold it from moving.
After clutch housing is removed, the clutch itself is threaded and by holding the shaft with pliers you can unscrew the clutch.
Past this, just screws holding the plastic housing.
Posted on Nov 28, 2010
I am trying to remove the outer spool assembly. How do I do it?
What does it say in the user manual? Or possibly you don't have one and haven't gone online to get one.
Anyway, most of these spools are removed by pushing two lugs together while pulling the spool away from the housing. Replacement is by just positioning the spool and pushing it into the housing until it clicks into place.
Jun 29, 2015 | Troy Bilt Tb70ss Gas Trimmer
Need to remove the entire head on troy built gas trimmer TB525EC and replace with Ugly head
if by the head you mean the angle drive on the end of the shaft, remove the clamp bolt or locating screw and pull the angle drive off the shaft
and other angle drive with the same shaft dia will fit back on
select an angle drive with a serviceable spool arrangement
May 05, 2017 | Garden
Cannot remove outer spool on TB70SS
Please see pages 12 & 13 of your manual here with instructions and diagrams on this procedure:
http://dl.owneriq.net/b/ba4ffa69-7dbc-4494-b691-3aa0cf7b3c3a.pdf
Jul 17, 2011 | Troy Bilt Tb70ss Gas Trimmer
Do you mix the gas and oil together with the Troy-Bilt4 cycle TB575SS. Lost directions. Thank you
No. You do that for a 2-stroke engine. Your engine should have oil in the crankcase and you just need to check the level of it and add gas to it like a regular lawnmower engine.
Sep 06, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Have a troy built TB575SS trimer. Pull cord has lost tension and cord is just fully hanging out. How do I I take unit apart to re-adjust cord tension?
The starter recoil spring may have possibly broke or the rope is hung up somewhere on or in the pulley. A lot of these units are assembled using Torx (Star) head screws and disassembly requires a couple different sizes to accomplish. Take your time...you will see the screw heads, but reloading a starter spring for a trimmer is a little tricky and you may need help doing so, but you can fix this yourself.
May 29, 2010 | Troy Garden
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy Bilt Tb70ss Gas Trimmer Logo
978 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
