Question about Refrigerators
Bosh error It is a Bosch B30IR70NSP/03, 2008, type K1SDR3OUS. New, first time turn on. The mating freezer unit works fine, bothe professionally installed. The error message is Load 2
It is inappropriate because your advice was no idvice. It should have been obvious that I had checked the manual and performed the recommended tests before I actually paid money for advice. After all what kind of expert advice is "read the manual and follow the manual debug steps, I don't need top pay money for this.
I asked the question on Sunday because the Bosch helpline isn't open on Sunday and I was hoping for a quick soliution and got none. Oh, btw, Monday morning bright and early Bosch advised me that I had a very rare case of DOA compressor, they sent out a technician.
I notice I didn't get a response to my request for a refund based on the 12 hour response guarantee. Maybe I should open my own website, easy way to make a lot of money, pretend to be an expert and tell everyone to follow their manual!
Wonder how many other dissatisfied rating are "loclked"
Posted on May 07, 2008
  • Refrigerators Master
  • 13,433 Answers
  • Ekse May 07, 2008
    Now I dont see why you gave me innapropriate for this.
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
E 14 bosch washing machine!! aaagghh
i keep getting E14 on my bosch on my washing machine sometimes it works and other times fills with water then E14 comes up could anyone please help me .......
Mar 04, 2011 | Bosch WFK 2401
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
My bosh washing machine not washing.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 07, 2009 | Bosch Logixx WFT 2806 Front Load...
Dishwasher won't drain -it's only 3 months old
Yes they do have a drainage problem! I worked for a Sear install team. You need to have the installer come back out, if they did the install correctly and you still have problems then sears needs to send a service tech out. If they can't fix it or tell you it is a install error then be persistent and tell them you want a BOSH TECH out. You more than likely need a stronger pump as Bosh DW work off a gravity type pump system. Keep in mind Sears installers guarantee there install for 1 year and all products come with a 1yr MF warranty. If you purchased a warranty or PA agreement the you will be entitled to a new unit if that one is not fixable. If you have a garbage disposer, they work best when routed into one.
Jan 17, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosh shu43c never stops running.
If you have a Bosch shu4300...check this site.
http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/
My issue was a heater fault and fixed the problem by resoldering a bad joint. Works fine once this was fixed.
Nov 24, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Sep 29, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
