Question about Baby Gear
A screw fell out that secures the handle to the frame of our double stroller how can i replace it?
  • 490 Answers
There should be a second screw still in place.If this is so, remove it and take it to the local hardware store for a match. Otherwise, if you can tell me the manufacturer and model, i may be able to locate a source for OEM parts. Hope this helps a little:)
Posted on Aug 23, 2010
How to fold mia moda 3 wheeler
Step 1
Inspect the stroller's wheels and handle to identify the type of brake mechanism it has. If the device is equipped with wheel-mounted brake levers and swivel locks, use the toe of your shoe to activate these mechanisms. If your stroller is equipped with a handle-mounted brake lever, push down on the lever to engage the brakes. Some models also come equipped with a secondary-locking mechanism located on one of the rear crossbars; use the toe of your shoe to activate this feature.
Step 2
Lift the handle or press the tab securing the backrest in place, located on the upper edge of the backrest or on the crossbars securing the rear of the backrest to the frame. Grip the edges of the footrest, then lower the component by pushing it into the desired position. Pull back the stroller's canopy.
Step 3
Grip the stroller's handle and lift the device upward; if the stroller comes equipped with a safety button, press the button as you lift. Use the toe of your shoe to push on the stroller's hinges until the frame begins to fold.
Step 4
Pull the halves of the stroller's frame together until you have completely folded the device; if the stroller comes equipped with a locking latch, engage the latch to keep the halves from sliding apart.
Audi Parts
May 23, 2012 | MIA MODA Atmosferra Travel System Stroller
Fixating mechanism in handle is broken
Ok, how is the frame broken ?
what is it made off ?
please reply with more info.
Mar 02, 2008 | Chicco 3WD Tech - Canarie Stroller
The left side of the handle bars of stroller will not open to full position and the rest of the handle bars are too low (by my waist). The stroller was fine and the next time I used it this happened. The...
The only thing I can think of is if it is bent, to try straightening the bend. Be very careful as the frame is hollow and too much pressure will cause it to collapse. Do not try to use a hammer as this will collapse the frame. If you do not have the strength to bend the frame, ask someone you know to help you.
Best of luck Jamie!
Jim
May 31, 2011 | SafeTech Double Jogging Stroller
I received a replacement handle for my mutsy urban rider stroller, but cannot detach the broken one in order to replace it. how do you remove/replace a broken handle?
Remove the 5 screws from each seat holder clip. Remove half of the seat holder clip. Removing these will allow the handle to slide out. Hold the release button on the handle and pull the handle out of the frame.
Jan 10, 2011 | Mutsy Urban Rider Next Standard Stroller
Where is the serial number and the manufacters date on the stroller
It is engraved on the frame, on the right rear, above the right rear wheel. (City Elite Single )
It is engraved in the frame, on the right side of the stroller, on the lower side of the right folding handle, under the logo. (City Elite Double )
Dec 03, 2010 | Baby Jogger Onyx 2010 City Select Stroller
The entire back wheels fell off our double eddie bauer stroller - both wheels on the right and the left. We've tried to replace wheels without success. Can we order the wheels somewhere? thanks.
When you say the wheels fell off did they break of at the spokes (making the wheels useless) or did they just come off the metal stub axles? The Eddie Bauer is not a brand available in new Zealand but I've fixed a lot of strollers and the most common problem is a failed Star-lock washer. Most strollers use a star-lock to hold the wheels on, either a shiny domed one in plan view or a plain flat one hidden behind a plastic hub cap. Check this out www.bakfin.com/starlock/starlock-movies.html
Dec 03, 2010 | Eddie Bauer All Terrain Tandem Double...
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
The front wheel fell off
You may need to go to tireshopes but im afraid you will have to go to the dealer ship of chrysler/dodge dealer
Jul 19, 2009 | Jeep Twin Sport All-Weather Umbrella...
Straps ripped on my Instep double jogging stroller (11-KA200)
Instep does have replacement parts for some of their strollers. For $25 I was able to purchase a new seating pad.
Apr 18, 2009 | InSTEP 10K Double KA200 Jogger
Babytrend stroller frame's collapsing lever has lost some screws
Call Baby Trend at 1-800-328-7363 to find if replacement parts are available.
Mar 13, 2009 | Baby Trend Snap N Go 1308 Stroller Frame
Baby Gear Logo
195 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
