I want the fuction book of samsung washing machine DC68-20092C
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
F-05 MESSAGE HAS COME UP ON MACHINE WHAT DOES THIS MEAN?
hi have a look below hope this helps, then goggle how to fix it!
Sep 06, 2011 | Hotpoint Aquarius WD640 Front Load...
My washing machine doesnt carry out the rinse fuction and gives an error of 5E or SE.
It is a computer problem and you can get it fixed free, due to a recall by Whirlpool. Call the company and complain. My daughter had the same problem.
Jul 16, 2011 | Washing Machines
I have a samsung washing machine model 2005 serial number. 209154BY500039J and having aproblem in setting kindly send me manual book for assistance.
You will need to type into your search engine/web browser 'samsung washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 14, 2011 | Samsung Washing Machines
Washing machine motor need tentioning when spen drying all of the water not going out
the belt is a preset size usally there is no adjustment for it make sure they gave you the right belt the belt if you are replacing it the belt mainly controls the spin fuction on the machine as well as the agitate the pump is what controls your water being removed fromthe tub hope this helps
May 18, 2010 | Admiral AAV7000A
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
English manual for new Samsung Pixon M8800
i had a simular problem my booklet was in greek or maybe russian
i managed to find a basic intruction book if you want it email me and i'll send it when i get home
its a pdf file it mostly explains key fuctions etc
unfornatley it didnt help me with problem
lava@exemail.com.au
Feb 23, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Washing Machines Logo
173 people viewed this question
Top Washing Machines Experts
