My amana washer model ntw5640tq0 does not stop filling up with water. the drain tube is properly installed
    Novelist:
  • 177 Answers
Sounds like you have a pressure switch problem or the hose to the p/s has a hole
Let me know if you need more help
Posted on May 04, 2008
Wont stop filling
The fill solenoid is stuck in the open position. Replace it for proper operation. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
Filled with water. Took towels out - would not spin. Unplugged it. Now it tries to drain but stops and lid unlocks.
Amana , Whirlpool Washer Repair - Not spinning or draining ...
? 1:50
www.youtube.com/watch?v=q7ey58YZrm8
Jul 2, 2013 - Uploaded by ApplianceVideo.com Repair your own Amana Washer with these following issues: Not ... How to Fix a Washing Machine That Does Not Spin (Fast and Easy) ...
Sep 17, 2015 | Amana Washing Machines
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Top load washer won't stop filling with water
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
or
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Nov 08, 2009 | Amana NTW5100TQ Top Load Washer
Kenmore Elite washer will not stop filling
Dirt in your solenoids may be a problem. But other than that it could be bad solenoids in general. It could also very well be that the unit that senses the water level has a part broken. On the inside there is a tube that connects to the tub. When you add water it increases the pressure in the tube and signals the shutoff. Sometimes the connections on this tube go bad.. or the tube itself gets a hole.
Easy way to tell. Start the unit with the on/off switch. Wait a few seconds then turn it off again. If the water flow doesn't stop you're most likely looking at a solenoid problem. If the water flow stops when you turn the switch off then you're most likely looking at a problem with the water level sensor.
Jul 29, 2009 | Amana ALW880WH Top Load Washer
Water Drains out as fast as it is filling
You have too much of the drain hose inside the drain line causing the water to siphen out as its coming in. Pull some of the drain hose out and secure the hose. There should only be about 8 inches or so of the hose inside the pipe.
Apr 08, 2008 | Amana ALW880WH Top Load Washer
Amana Model NPW5400TQ0 Washer
REPLACE THE TIMER OR Power control BOARD
Jan 30, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
My washing machine doesnt stop filling the tub when the right water level is reached, it will just continue filling and never stops filling. Can anyone suggest what is wrong and how to fix this?
Not familiar with this model. When a washing machine fills with water up to a predetermined level, it usually operates a pressure switch which will turn off the water valve, and redirect the power to the programmer, or heater, or some other stage of the programme. If there is a blockage of powder or gunge in the tube leading to the pressure switch this would prevent air from rising up the tube to operate the switch. Tom.
Feb 27, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
