Question about GE Washing Machines
Washer drains as it is filling so it never gets past the filling stage
    Champion:
  • 245 Answers
Your drain hose is to low. Give me a rating if I am correct!
Posted on Aug 23, 2010
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
Just got a new maytag bravos washer and it will not go past the sensing stage and as it puts water into the washer it drains as fast as it goes in
You must make sure the drain hose is above the water level and not in the water in the "P" trap of the house drain. There must be air to prevent siphoning. The drain hose should not go more than about 12" down in the drain tube.
May 28, 2011 | Maytag Bravos MTW6600T Top Load Washer
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
Our washer fills and drains at the same time.
Hi, Based on the limited info I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far. If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, and if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon. Do you hear any motor operating while this is happening ? If you answered NO, this further support's the idea of the washer siphoning out the water it is supposed to fill with. Check your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. Thank's for coming to "fixya" and good luck. Macmarkus :)
Apr 10, 2010 | GE WJSE4150B Top Load Washer
Washer fills and drains at the same time.
Check for congealed soap in the Air Bell which is at the other end of the pipe for the pressure switch
Apr 02, 2010 | Kenmore HE2 Plus Front Load Washer
Washer stops early cycle. In the first minute or two while it is filling with water it stops. If it gets past that stage it works fine.
gud day,,your washer has a little problem you must only adjust the washer timer,,you can fixed it by your self by opening the time at the back..tnx
Sep 09, 2009 | Kenmore 22642 Top Load Washer
Series 110 (old) Kenmore washer does not drain...
The drain pump may be clogged. I had the same problem and found a bunch of polyester fiber fill from a comforter my wife washed clogging up the water pump. Once cleared, it worked fine.
Dec 22, 2008 | Kenmore 24032\24036 Top Load Washer
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
My Frigidaire GLTR1670A stops when it gets to rinse???
mchacon, start with the pump. Remove the lower panel and the pump will be on the right. Grab a pan and some towels and remove the hoses going to it. Clean out any coins, lent and whatever from the drain hose trap. Check the pumps impeller for lint, pins etc. This model has a pressure switch that will not advance the timer if it detects water in the tub. Also both fill valves must be on. You will not be able to see it under the basket. This picture is from another cat that had the same problem....Catriver..post back.
Feb 01, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
