Question about Maytag MSD2454G Side by Side Refrigerator
Fridgerator running but fridge and freezer not cooling.
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 23, 2010
Freezer is cooling but the fridgerator is not?
check the radiator on the back of the fridge, check and see if theres dust ,if so cleane off the dust and make sure the fridge has 1 to 2 inches between the wall so it can breath. that might help.
Jun 12, 2012 | Refrigerators
Refridge or freezer not cooling evaporator fan and compressor running fan inside fridge running all inside lights on
HI welcome to fixya, THe compressor start overload is bad, They had a recall about 1-2 yrs ago. You will need a tech to replace the bad overload. Should be cheaper than a new fridgerator. And this could be under recall. You will need the frist 2 letters in ser/number I hope this helps
Sep 20, 2011 | Maytag MBR2256KES / MBL2256KES
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
The temperature of the fridge has risen to 11/12 degrees & wont come down? Freezer works fine! Any answers please
Don't know the make and model of your fridge, but most fridges have only one evap coil located in the freezer. The fridgerator compartment is cooled by a fan to blow air from the coil back into the fridgerator section. Check that the fan is working and the vents in the fridgerator are not blocked. Often the problem might be that the defrost circuit is not functioning causing ice to build up on the evap coil thus block the air flow to the fridge. If you seen any ice build up in freezer or refrigerator that could be the problem. If that is the case, then you need to have the defrost circuit troubleshot, typical failures are the heater itself or the defrost timer if you have an older model. Hope this helps you.
Oct 08, 2010 | Refrigerators
Not Cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfad
Jun 13, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Fridgerator not cooling
I've had the same problem and it is the thermister inside the freezer compartment. There is probably a ice build up there too. remove the 2 screws and check, you can fix this yourself and save $100 bucks.
Apr 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
Kenmore fridgerator is leaking water in the bottom 2001
the drain tube above &be hind ceiling has drain cup on older fridge this gets stopped up with gunk and stuff. held on back wall by 2 screws. This is a top freezer Your describing other wise the drain tube is in the freezer and you'd have ice in the floor of the fridge. If your fridge doesn't have it in the top back of the fridge compartment it is entirely in the upper freezer compartment and is still stopped up probably w ice and gunk. Defrost w hair dryer and while you can see the drain pan and hole pour in a cup of water if it goes down your good other wise blow out the drain with compressed air and retry the water. Please rate me accordingly and good luck.
Mar 13, 2009 | Refrigerators
Maytag MSD2454G Side by Side Refrigerator Logo
41 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
