Question about Meade ETX-125PE (500 x 127mm) Telescope
I have a 125PE only worked once the day it arrived after going through the instructions it slew up and down and left to right that was the last time it stoped slewing left to right taht was 4yrs ago help!!!!
  • 3,186 Answers
Return it to Meade for repair--
Here:
http://www.meade.com/support/index.html
Posted on Aug 23, 2010
  • Joe Lalumia aka TelescopeMan
    You might want to check for a broken cable between the scope and the handcontroller. Buy a new replacement cable, they are NOT expensive.
    If this does not work the follow these steps:
    1. Do a RESET on the hand controller
    2. Calibrate motors
    3. Train the drives
    4. Check TIME. DATE, and SITE to see if they are correct.
    5. Do a Calibrate sensors on Polaris
    6. Do an Automatic alignment
    If the scope does not work after the above procedure it must be returned to Meade for repairs.
Kobelco sr135 excavator won't slew right or left.
You have an hydraulic problem in most likeyhood. Check the fluid level, check the lines. I don't know exactly what a Kobelco is, but anytime a contractors piece of machinery won't slew right or left it has been a hydraulic fluid problem.
May 10, 2014 | Liebherr Excavator
My immobiliser wont let me start the bike
This may help you ... http://www.youtube.com/watch?v=RTy_JKI9cQ0 ... probably not.
Resetting your security system depends on which system you have. To do any of them, you must have the fob. If you don't have the fob, only Harley can clear. Be prepared to prove ownership when you arrive.
To reset the code with a TSSM equipped bike, you will:
1) Set your kill switch to off
2) Quickly turn the ignition switch on, off, on, off, on
3) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
4) Press and let go of your fob button twice (press fairly hard, it's designed to resist being pressed by keys and what not in your pocket)
5) Current PIN number will be displayed on odometer
6) Change the PIN by pressing the left signal until the desired number is reached
7) Press the fob button twice to cycle to the next number and repeat step 7
8) Press and let go the right signal and turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 2 through 4 must be completed in quick succession of each other.
Now you can have the bike armed, and disarm with the PIN (example PIN will be 25522 in the following steps):
1) Ignition switch to Accessories
2) Immediately press both turn signals at the same time (red key light on you speedometer will flash rapidly if done right)
3) Press and let go the left signal 2 times
4) Press and let go the right signal once
5) Press and let go the left signal 5 times
6) Press and let go the right signal once
7) Repeat for each of the last three numbers of the PIN (left 5 times, right once, left 2 times, right once, left 2 times, right once)
8) Red key on speedo will stop blinking if done right (security has been disarmed)
NOTE: Steps 2 through 7 must be completed in quick succession of each other.
To reset the code with a HFSM equipped bike, you will:
1) Have your key fob near the bike
2) Set your kill switch to off
3) Quickly turn the ignition switch on, off, on, off, on
4) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
5) Press and let go the right signal once
6) Current PIN number will be displayed on odometer
7) Change the PIN by pressing the left signal until the desired number is reached
8) Press the right signal to cycle to the next number and repeat step 7
9) Turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 3 through 5 must be completed in quick succession of each other.
1) Ignition switch to on
Feb 24, 2013 | 2010 Harley Davidson FXDF Fat Bob
I purchased a new battery for my Toshiba Satellite L505D-55983. The second time I turned it on it went as far as the desk top and then shut itself down.
as soon as you turn your coputor on it f1,if your battery is any good you should get in stroll down to start windows normally the programs you had should reload and it should be the way you left it. if doesnt work go trough the same proedure but hit f8 restore your computor to factory condition or restore it the day before it broke just follow instruction .you have a drop down menu with your name on it or the ststem itll ask for a password that would be the same as you use to get inthe computor be patient if its done right it take time to configure your windows .if computor doesnt turn on than the new battery is not any good
Nov 26, 2011 | Computers & Internet
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
Decora 6124H Timer
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
MotorFault
Hi
In response to your email the whole unit is being returned to supplier motor problem is manufacturers electrical fault the meade etx-125pe should have motor limiters fitted which stops the scope slewing more than two revolutions in any direction to stop potential wiring damage this unit does not have them or they are faulty hence motor fault.
Jan 18, 2009 | Meade ETX-125PE (500 x 127mm) Telescope
Sentry safe ob0100 wont open with 3 digit com
A1 locksmith say's If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Jan 01, 2009 | Sentry Fireproof Safe
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Celestron nexstar 11" gps scope
Be sure that the Azimuth Axis is Lock, you migth want to try and move the telescope in the Azimuth to make sure it is it is locked. Be carful not to force it. I have seen on some post where the locking part of the Azimuth somtimes breaks. and the Azimuth Axis will just spin freely Locked down or not.
May 19, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Meade ETX-125PE (500 x 127mm) Telescope Logo
71 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
