Question about Hotpoint NVLR333EE Dryer
My wife started the dryer the other night and 15 min into the cycle we could smell something burning.we discovered that the electrical outlet got so hot that the dryer plug and wall outlet were melting.i cut the main power to the outlet and took the dryer apart thinking maybe there was some lint buildup overworking the dryer but its not to bad inside the vent pipe or around the drum.could the heating element have gone bad or the thermostat maybe?
  • Hotpoint Master
  • 43,501 Answers
The problem was not in the dryer, but it was a loose wire in the plug or the outlet...I have seen this happen many times.. the wire gets loose and then because of the poor connection it heats up and starts a fire...
Replace the outlet AND the plug!!
The dryer pulls a lot of current but it is not the problem...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Posted on Aug 23, 2010
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Will not drain water can i fix this
sounds like a bad dump valve. and yes you can replace it. take your serial number and modle number of the manufactures name plate down to your local appliance store and have them order the part and replace it
Dec 02, 2012 | GE Spacemaker Washer and Dryer Electric...
Smelled electrical burning last night and unplugged my GE profile dryer and one of the prongs(3 prong type) was burned
This usually indicates a loose connection. Check the wire connection inside the outlet and the connections on the back of the dryer. Make sure the nuts are not cross threaded, this commonly happens with the fine thread. When a loose connection happens the electricity will generate heat trying to make the connection, the cause of many home fires every year.
Oct 15, 2010 | GE Profile Harmony DPGT750EC Electric...
I just bought a used Amana Dryer LEA30aw and when I turn it on it has a slight burnt smell. What could this be?
sometimes youll smell burning lint or dust.let it run 10-15 mins outlet temp should be no more than 160'.smell should go away after a couple of mins.if temp exceeds 160 may need tstat.please rate my solution
Dec 06, 2009 | Amana Dryers
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not start
IT SOUNDS AS THOUGH YOUR MOTOR HAS LOCKED UP AND FAILED. THE BURNING SMELL IS THE VARNISH FROM THE WINDINGS OF THE MOTOR. REPLACE THE MOTOR. THEY CAN BE HAD FOR AROUND EIGHTY DOLLARS
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer smelling hot and smoke detector goes off
clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Mar 21, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
141 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
