SMC 11n Router: wireless set-up
Problem: Internet not loading for a second computer (iBook G4) even though base computer is connected and wireless configuration completed. Airport receives a good signal.
Light on this problem? I must have missed something silly.
Lilya
  • llmember May 05, 2008
    Thanks for the reply! What should I do with the address?
    Lilya
  • 77 Answers
Hi there!
Do you know how to check the wireless IP address at your iBook?
Posted on May 04, 2008
  • HAAi
    HAAi May 07, 2008
    Hi!
    Did you already check it's IP address? Is it within the same IP range of your router's?
    I'm not sure but you can try this to check it out if you don't know how to:
    Click at Apple Icon > System Preferences > Network > Chose you wireless adapter (Airport)
Can my apple ibook g4 work without an airport extreme card
If you mean 'work as a computer' then the answer is yes.If you mean 'work on the internet' the answer is yesIf you mean 'work wirelessly on the internet' then the answer is no.
You can use an ethernet cable to connect to your Router and that will give you the internet.
Feb 18, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Hardwired pc cannot recognize network (local access only)
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
Note: Name (11N SSID) is for wireless N computers running at 5GHz and the Name (11G SSID) is for wireless G computers running 2.4GHz. Kindly make sure that (11N SSID) and (11G SSID) names are different.
c. Set the mode to Up to 270Mbps at 5GHz & 54Mbps at 2.4GHz.
d. Set the 11N Channel to 48 / 5.240GHz and 11G channel to 1 / 2.412GHz.
e. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
6. Connect wireless computer to the router.
Note: If your wireless computer supports 5GHz and 2.4GHz frequency you will see two wireless networks which are 11N and 11G SSID. However, if your wireless computer only support 2.4GHz frequency you will only see one wireless network which is 11G SSID.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet with the ideal speed you have from your ISP.
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Who is your internet service provider? Is it Cable or DSL connection?
2. How many wired and wireless computers are connected to the router?
May 16, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Cant remember my password for my wpn824 netgear
please try;
username: admin
password: password
If this didn't work, you have no choice but to re-setup your wireless router. Here's the detailed step by step procedure.
5. Power cycle.
Apr 10, 2009 | NetGear RangeMax WPN824 Wireless Router...
Continues lost of connection using router
- Kindly make sure you already configure the required ports of emule to your router.
Mar 14, 2009 | SMC Barricade N Draft 11n Wirele Router
Netgear wndr3300 5.0 ghz range
5. Power cycle.
Feb 02, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
Netgear Rangemax Router not supported/can't find wireless networks after first time it logged on.
Lets do it again...
5. Power cycle.
Aug 24, 2008 | HP Pavilion dv8000t Notebook
I need to connect a real router with more ports to it 4-2 pcs
Connect the LAN port on the Barricade to the WAN port on your wireless router. The Barricade should be "plug-and-play",
i.e., no need to configure it. Similarly, the WAN port on the wireless-router is plug-and-play, so it should automatically get an IP-address from the Barricade.
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Then, start Internet Explorer, and connect to the web-server "inside" the router. Run the "Wired Network Setup Wizard", and then the "Wireless Network Setup Wizard". When you're done, then your "wireless" device(s) (iPod Touch, laptop, XBox360) should be able to make a wireless connection.
Note: no need for any CDs to "install" anything.
Sep 23, 2007 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
