Question about Craftsman Air Tools & Compressors
It will start to run but seam kinda slow and will pop the breaker after 10 seconds. it is a upright 5 hp. ran fine and then not no lead in to the prob.
  • 366 Answers
Make sure the service that you have the compressor plugged into is sufficient to run that big of a motor. ie, a 20 or 30 amp breaker/service.
Posted on Aug 23, 2010
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
My 2002 subaru outback starts just fine but dies within 10 seconds
sounds like a bad fuel pump.
its getting enough fuel to start then its starves after it starts
Dec 23, 2013 | Subaru Outback Cars & Trucks
I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Circuit breaker on my air compresor pops
does the breaker pop with an empty tank?
if so then you need to see if the unit turns free,try running the m/c disconnected from the pump unit,my guess is that your drive motor bearings or internal windings are at fault
hope this helps regards ian
May 03, 2009 | Air Tools & Compressors
Blowing the breaker
Sounds like you have a bad nutural feeding to the main or its set up for 110 and running on 220. Check the incomming voltage at the wire feed to the motor. If anyone has replaced a breaker or a wall plug close to the unit or any palce in the structure Im betting this feeds back to your air compressor some how. and somethign is differant than it used to be.
Their is no way it could turn faster unless the voltage is way up. Chack the Name plate also on the motor some are dual voltage and maybe its wired up for low volts and on higher. Catch it early like tbhis and it will be ok.
PLEASE RATE ME ACCORDINGLY I THIS HELPS. And GOOD LUCK
Mar 02, 2009 | Ingersoll Rand Compressors 5-HP,...
Furnace keeps tripping circuit break
Furnace. To confirm use an Ampprobe or other brand ampmeter and see how much current is being drawn. If it is more that 80% of the breaker rating, it si for sure the Furnace.
Jan 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
Air Tools & Compressors Logo
93 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
