I have a document in Works consisting of 4 pages but my new HP computer needs to be configured as it will only print the first page
  • 77 Answers
Hi there!
Is it with Microsoft Word? If Yes, then you might need to check this out:
File >> Print >> Page range >> ALL
Hope this helps!
Posted on May 04, 2008
Hp cm4540 configration device code
Not sure if you just want to print a configuration or if you have an error code. To print a configuration page
  1. Scroll to and touch the Administration button.
    1. Open the following menus:
    1. Reports
    • Configuration/Status Pages
    • Configuration Page
  • Touch the Print button to print the report, or touch the View button to view the report on the screen. The report consists of several pages.
    I
    Aug 24, 2014 | HP LaserJet Office Equipment & Supplies
    Cannot print from computer. printer will print test pages, though
    How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
    If Printer is connected USB than try different USB Cable and try different USB Port on the computer
    If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
    If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
    Oct 16, 2009 | HP Color LaserJet 3500 Printer
    How to wirelessly print to HP 2410v Photosmart printer
    This is the official how-to for network setup from HP:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
    Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
    1. Press the Setup button.
    2. Press the arrow buttons to select Network and then press OK .
    3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
    Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
    The manual link is here:
    http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
    Hope this helps:
    WizardRepair
    Jul 18, 2009 | HP Office Equipment & Supplies
    HP photosmart C5280 document stuck in print que
    Delete document manually from the path mentioned below:
    1) Press windows + R an then type spool
    2) Go to PRINTERS folder.
    3) Delete the files present in there.
    If not able to delete then
    1) Open command prompt.
    2) type "net stop spooler" and then delete the files
    3)Again type "net start spooler"
    Your stuck document is now cleaned. You can start printing your document again.
    Mar 30, 2009 | HP Office Equipment & Supplies
    HP laserjet 5L prints only 2/3 to 3/4 of the page of a 1 page doc
    which bit is usually missing?
    If it only prints the 1st 3/4 ish of the page then it could either be the page slipping a bit due to poor pick up rollers or much more likely it could be that you are sending a large file to the printer and the printer does not have enough memory.
    Try printing in draft or scale down the res/size of the file you are printing
    Mar 18, 2009 | HP LaserJet 5L: HP 5L Monochrome Laserjet...
    Unable to configure the HP C6380 for double-sided printing
    Here is the step by step right from the user manual. also here is a direct link to the manual.
    http://h10032.www1.hp.com/ctg/Manual/c01527492.pdf
    Let me know how it works out for you.
    Print on both sides of the page
    You can print two-sided pages with the HP All-in-One manually. When printing two-sided
    pages, make sure to use paper that is thick enough so that images do not show through
    to the other side.
    To print on both sides of the page
    1.
    Load paper into the input tray.
    2. On the File menu in your software application, click Print.
    3. Make sure the product is the selected printer.
    4. Click the button that opens the Properties dialog box.
    Depending on your software application, this button might be called Properties,
    Options, Printer Setup, Printer, or Preferences.
    5. Click the Features tab.
    6. In the Paper saving options area, select Manual from the Two-sided printing dropdown
    list.
    Perform special print jobs 83
    Print
    7.
    For binding, do one of the following:
    • For binding on the top like a notebook or calendar, select the Flip Pages Up check
    box.
    This causes the odd and even pages of your document to print opposite of each
    other top-to-bottom. This ensures that the top of the page is always at the top of
    the sheet when you flip the pages up in your bound document.
    • For binding on the side like a book or magazine, click to clear the Flip Pages
    Up
    check box.
    other left-to-right. This ensures that the top of the page is always at the top of the
    sheet when you turn the pages in your bound document.
    3 5 1
    8. Click OK, and then click Print or OK in the Print dialog box.
    The product begins printing. Wait until all the odd-numbered pages are printed before
    removing any of the printed pages from the output tray.
    A dialog box displays instructions on the screen when it is time to process the second
    side of your job.
    9. Click Continue when done.
    Nov 28, 2008 | HP Office Equipment & Supplies
    Plz help me am in trouble
    Network Configuration page
    NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
    HP LaserJet p215tn, and HP LaserJet p215nw printers.
    A Network Configuration page prints whenever a printer configuration page is printed. You
    can also print a Network Configuration page by pressing the network Reset button at the
    back of the printer
    The Network Configuration page provides information about the network configuration,
    including the IP address, firmware revision, network statistics, protocol information, and so
    on. The Network Configuration page automatically prints when you print a configuration
    page from the control panel.
    ENWW Printer information pages 37
    Using the HP Toolbox
    The HP Toolbox is a Web-based program that you can use for the following tasks:
    ● Check the printer status.
    ● Configure the printer settings.
    ● View troubleshooting information.
    ● View online documentation.
    You can view the HP Toolbox when the printer is directly connected to your computer or
    when you are using a supported network connection. You must have performed a complete
    software installation to use the HP Toolbox.
    NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
    click a link in the Other Links area, you must have Internet access in order to go to the site
    associated with the link. See Other links for more information.
    To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
    of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
    all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
    connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
    administrator or computer manufacturer's documentation for more information about
    installing the TCP/IP protocol and the DOT4 protocol.
    Jan 22, 2008 | HP LaserJet P2015dn Printer
    Word 2007 Booklet Graphics print on wrong page.
    did you try to preview your work and see if its coming out on the page like you want before you print try that and see if it looks right before you do your work, I don't know if that will help you out but I hope so.
    Dec 31, 2007 | HP Media Center m7060n PC Desktop
    Why do all pages print onto one page when i hit the print button in a multipage document
    I guess you are using word. In that case the default driver you use and comes standard with windows is flawed. Download a new one from HP.
    Oct 24, 2007 | HP LaserJet 1150 Printer
    HP 4650N Will not print more than one copy of a job
    make sure when printing it has all checked off in the page range box instead of pages
    Aug 28, 2007 | HP LaserJet 4650n Printer
    Computers & Internet Logo
    23 people viewed this question
    David Payne
    David Payne
