Question about Refrigerators
BOARD ASM MAIN DOMESTIC QUESTION HOTPOINT
BOARD ASM MAIN DOMESTIC QUESTION HOTPOINT HSS25IFMDWW Side-bySide Refrig Replaced faild defrost thermostat (potting ruptured - case opened up) OHMed out thermistors and heater. Heater was 22 OHMs. Cleaned condensor coil. Compressor is running and freezer works fine until ices up. Appears no defrost cycle. Unplugged and manually defrosted; restarted unit. Is there a series of checks for the motherboard ?
SOURCE: Warm Freezer and How do I set or reset the defrost mode
smoke smell coming from fridge, open back cover and a smokey cloud came out of the compressor what's going on with fridge?
Posted on Aug 17, 2007
  • 1462 Answers
SOURCE: Refrigerator GE GSS22KGMDWW defrost failure
it could be that too much ice is forming for the heater to cope with. check the door seals
Posted on Sep 14, 2008
tborn6
  • 700 Answers
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
Posted on Mar 07, 2009
aasc
  • 1606 Answers
SOURCE: I have a Hotpoint HSS25IFMD WW sise by side
A thermistor is a 2" torpedo looking piece with 2 wires attached to it . The defrost bimetal , a 1" round aluminum piece , snapped onto the coils , with 2 wires , should be replaced when replaceing the heater . This bimetal could be the problem . To test the defrost system , remove the main control board cover . The blue plug with 3 wires to it needs to be connected . Looking at the plug , the wireing will look like this : l l l . Lets call the terminals 1 2 3 . Useing a piece of insulated wire with both ends stripped , insert one end into terminal 2 and the other end into terminal 3 . The heater will come on if both the heater AND bimetal are good . If you put a new heater in and it wont come on , and you do this test , then the bimetal has to be bad . If your terminology is correct , you have 2 thermisters in the freezer . One on top of the coils ( evaporator sensor ) and one at the bottom by the drain pan ( freezer temp sensor ) . Wouldn't hurt to replace both if you replaced one .
Posted on Aug 08, 2009
EllaWatson25
  • 725 Answers
SOURCE: Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Posted on Aug 14, 2009
I have a hss25ifmdww thats not cooling the compressor is not coming on how can i check to see if its a bad control board or compressor
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire1 , and the other into wire3 . Plug the refrig back in and see if the compressor now runs . If it does , replace the board . If not , compressor is bad . When testing , ONLY the compressor will run and nothing else will .
Jan 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator side not cooling, there is a lot of frost on the coils of the freezer. I have defrosted once, cleaned the evaporator coils and fan, then it just froze up again. What do you think?
Most likely , the problem is a bad defrost heater , pt # WR51X10055 , but I would still suggest going thru the motions to make sure . The heater runs about $45.00 .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature
Oct 04, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My side by side hotpoint will not defrost itself..it's only 3 years old..just a simple water ice sbs
no defrost may be a bad p c ( main board ) or bad heater 9 most common ) and a defrost terminator . ( not to common ) .. mm
Aug 10, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Where is the defrost timer located on a G E side by side frig?
Your fridge does nt have a defrost timer. For the model PSS26MSRSS you will need a main board linked below.
Thanks for asking.
Main board
May 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi there. My GE GSL25JFPD side by side has major issues. The evaporator has completely frozen over. We called a technician twice. The first time he replaced the main electrical board. This fix lasted about...
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board .. Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Nov 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Evap. blower motor not running.
You have a bad main control board . Usually on HSS models , when one of the fans don't work , its due to burnt resistors on the board (not the motor) . only way to fix , is replace the board .Patr # WR55X10656
Jul 28, 2009 | GE Refrigerators
REFIGERATOR AND FREEZER NOT WORKING
Was the unit completly defrosted? Did the tech check to see if the compressor came on? Also, when the board is replaced, depending on the unit, there are wire to be cut so the board will work with that particular model. Check to see if the compressor is running first. then make sure the unit was defrosted. the other problem could be one of the thermistors deffrctive that control the defrost..
Aug 01, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
