Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Self cleaning oven says steam clean and add water to what
  • Anonymous Mar 21, 2014
    water is still in oven pan
  • Whirlpool Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Aug 23, 2010
Instructions for beko self clean oven
the self cleaning ability of self cleaning ovens is to do with the linings. If yours are getting stained, try putting an oven proof bowl with water in it whilst in use. That should help.
Aug 03, 2014 | Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Condensation in oven door glass after steam clean
    No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
    Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    How do I use the steam clean self-cleaning oven?
    The SteamClean option spot cleans the oven in 20 minutes and is recommended for cleaning light spills on the bottom of the oven cavity. When used routinely, the SteamClean option reduces the need for frequent self-clean cycle use. To use the SteamClean option, pour 12 ounces (1 1/2 cup) of water into the bottom of the oven cavity, close the oven door and push the SteamClean button. At the end of the cycle, consumers wipe out the bottom of the oven, easily removing oven soils. The steam cleaning option is eco-friendly and does not require frequent use of the self-clean cycle, which can create a strong odor. Read this in a post about the new whirlpool ranges
    Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Neff oven B1641
    Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
    Feb 27, 2009 | Neff B1641 Single circotherm super...
    How do I descale a Miele steam oven?
    Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
    Hope this helps
    Jan 31, 2009 | Miele DG155-1 Steam Oven Single
    Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
    NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
    Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
    Self clean
    I have a B1422 oven and it doesn't have a self cleaning option. It does, however, have a clean assist option.
    If you have a box with what looks like a teardrop in it then your oven has the same system.
    What you do is pour a mix of water and washing up liquid into the base of the oven moz-screenshot-1.jpgmoz-screenshot.jpgand switch the controller to the teardrop. The bottom element will then warm the liquid, and the resulting steam loosens the grime. You then use good old elbow grease to clean the oven.
    May 17, 2007 | Neff B1421 Electric Single Oven
    Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    730 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
