Question about Kenmore Dehumidifiers
Where do I find a manual for my Kenmore dehumidifer Model # MDF-30AE- Thank so Much,! Alannah K Ashlie
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Sears Kenmore Dehumidifer Model # 580.54501700 and
You can get the manual on the link below.
http://www.managemylife.com/mmh/owner_manuals/7614/KENMORE-Dehumidifier-L0709045?brand_name_search=580.54501700+
Good Luck and please rate 4 thumbs up for your free answer.
Posted on Jun 23, 2010
joeguest2
  • 2080 Answers
SOURCE: Hi. My Kenmore dehumidifer model 580.53509 or
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means the unit itself is actually working well. The humidity level in the room may be relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work. Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
Sometimes the drain tube leading to the bucket is clogged. You can often clean this out by inserting the pointy end of a long heavy duty plastic zip tie and jiggling it around a bit. Do not insert anything metal or sharp into the tube or you may damage it.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
And here is a link to a tip from another Expert (Heatman101) which includes his very detailed troubleshooting guide for dehumidifiers:
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
I hope that was helpful to you, good luck.
If you choose to rate this solution, or Heatman 101's tip using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 31, 2011
Power button is blinking on polar wind model MDF1-30AE dehumidifier?
The tank closes an interlock when it is reinstalled and operation is restored. The tank may not have been reinstalled in such a way as to close the interlock.
Sep 08, 2014 | Dehumidifiers
I am looking for a manual for a munters MH 240 dehumidifer
I would contact the manafacturer. I fouond the 270 at: http://www2.munters.ru/pdfs/MH270.pdf. The contact information is:
Munters Europe AB
Dehumidification Division
Box 434
S-191 24 Sollentuna
SWEDEN
Tel: +46 8 626 63 00
Fax: +46 8 626 63 65
Feb 05, 2014 | Dehumidifiers
My Kenmore Elite Dehumidifier model 42-99701 runs but does not cool enough to collect water. Not a drop. found this page where I can order parts but I don't know what part I need to replace. Please help....
Dehumidifers are cheaply made and most likely it has formed a refrigerant leak. It would cost more to repair than to replace with a new one. They are basically a disposable appliance.
Oct 12, 2013 | Kenmore 54501 Dehumidifier
Model 580.51450100
Go by a local air conditioner supply house and ask them. Usually if they can't get the part they know where to go to get parts for home appliances like Dehumidifers. Take the fan motor with you they may have something on the shelf that will work.
Jul 15, 2013 | Kenmore 54501 Dehumidifier
WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
Needs to connect drainage hose to dehumidifer
There will be some form of lever or activation device that depresses when the bucket is inserted. There should be a way to move it to a permenant "on position". Make sure you have a model with a humidity sensor or the thing will just run forever. It may be that if your model doesn't have a humidty sensor there is no way to "force" it to stay on although that would make no sense if there is a hose attachment to drain constantly to a sump pump, etc. Have you tried going to a store like Sears and just looking at a dehumidifier? Ask a clerk how the thing works if you attach a hose to it. You might be surprised what you can learn from just nosing around the hardware and small appliance section.
Dec 14, 2008 | Kenmore Dehumidifiers
Kenmore Dehumidifer P1 Problem...
I heard that the code P1 meant defrosting mode, and it will restart normally after it is done defrosting.
Apr 06, 2008 | Kenmore 53701 Dehumidifier
Dehumidifier Kenmore 580.54501
hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Jun 11, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
