Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
Timer on my 200W transformer is working but lights will not turn on manually or by timer. when i turn on with manual switch they flash on for a second then turn off. i am just under 200W for total wattage.thanks!
You posted under Intermatic-malibu power packs.
Wattage of bulbs must match wattage of power pack or bulbs and power pack will burn out.
Your power pack might be damaged beyond repair.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Mar 21, 2011
Resetting a tripped kitchler low voltage transformer
Model number is not known.
I did not know that Kitchler transformers have a circuit breaker.
Usually they have an override switch.
Did you set the timer to override, what does your product manual say?
Is the transformer humming? Kitchler transformer are supposedly non-audible, but there should be some indicating sound. The humming sound indicates the transformer is working.
Does the unit have photoeye? Cover photoeye with black tape.
Test outlet with circuit analyzer.
Check outlet voltage: if you have 120Volt then output is 10% or 12Volts. If you have reduced voltage, then output is still 10% but might be lower than needed to operate bulbs.
Plug timer into different outlet.
Test output terminals with low voltage tester.
Did you have power outage or nearby lightning strike? Transformers are not protected from surge.
Suggest you contact kitchler.
Kitchler.com website is useless
888-412-4877
7711 E Pleasant Valley Rd
PO Box 318010
Cleveland, OH 44131
Kitchler products are probably warranted through the seller.
Kitchler product manuals are almost non-existent.
Scan your product operating manual and parts list into .pdf format and post on web for others to access.
Aug 09, 2012 | Hardware & Accessories
Where do the wires go to a b c for a ml814drp phote eye
When wiring photo-eye to power pack, the wiring is changed from what shows in power pack manual:
Open following links for power pack resources:
http://waterheatertimer.org/pdf/Intermatic-malibu-photo-eye.pdf
Photo-eye manual shows correct wiring:
Photo-eye: Solid-black-wire to A, red-wire to C, middle-wire to B.
Lights: wires to lights are moved to terminals B and C
Jul 21, 2011 | Intermatic 200W Power Pack With 12v...
Timer turns lights on for 2 seconds then shuts off ?????
Timer is malfunctioning, or trippers are worn down and don't fully push the switch over.
See it timer operates on manual override.
Buy new trippers, and/or buy cheap plug-in timer, and then set power pack to override, and plug power pack into cheap timer.
Power Pack uses 107SB189 ON tripper, and 107SB192 OFF tripper
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, links to manuals, useful links, warranties and tips:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 10, 2011 | Intermatic 200W Power Pack & 12v...
Lost manual for ML300RTW transformer. Does this transformer have an override so I can plug into exterior timer? If so, where is it?
Yes power pack has override, depending on model.
There should be a small knob located above and to left of dial that rotates: Step 8 in Manual says: You can manually operate the lights by turning the Manual ON/OFF Switch counter clockwise.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml300rtw%20ml300rtwsn%20trilingual.ashx
For information on Intermatic/Malibu power packs showing links to manuals, troubleshoot steps, replacement trippers, useful links, warranties and tips:
Apr 02, 2011 | Intermatic Malibu 300W Power Pack...
Timer dial does not move must use manual switch on timer to turn lights on
If I understand correctly, you have a Malibu power pack and can manually turn lights on-off but timer is not working.
1) 'Harry' wrote fixya with a work-around for this problem. He bought cheap plug-in timer. Set power pack to override and then plugged power pack into cheap timer.
2) Harry also said he has 5 year warranty and was negotiating with malibulights.com for refund.
No word how that came out.
3) Other than Harry's solution, I have not found repairs and parts for power packs.
After hours of reading manuals, searching Malibu, Intermatic, ebay etc I found nothing.
There are folks who write fixya how they took apart their power pack, but nobody reported fixing a power pack once it goes bad.
4) Best I found are tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 21, 2011 | Intermatic 200W Power Pack & 12v...
Malibu Model: ML200TW Transformer Automatic timer not working
You can buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
I wrote power pack troubleshoot checklist:
http://www.fixya.com/support/r8391011-power_pack_not_working
Jul 23, 2010 | Intermatic Malibu 300W Power Pack...
Timer stops at on postion? transfomer works, have to do it by hand
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
May 04, 2010 | Intermatic Malibu 300W Power Pack...
Lights will turn on and off manually only
Just checking, still plugged in, fuse or circuit breaker not tripped that provides power to it? If you can turn it manually, and the dial does not turn when powered up, look for a small on/off switch, other than that, maybe it does need replacement, but they usually last longer that a year, but I have had some timers that just quit working on me too.
Apr 29, 2010 | Intermatic Malibu 300W Power Pack...
Malibu landscape transformer
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Apr 14, 2009 | Intermatic Malibu 300W Power Pack...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
207 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
