Question about Maytag EPIC MFW9700S Front Load Washer
I have a may tag epicz washing machine that continuously has the F20 eerier signal. We checked the hoses, drainage and filter. There is plenty of water, in fact the cloz are drenched dripping wet when the F20 signal comes on. It is almost as If the drum is too heavy with the wet cloz and will not spin. Plenty of water, no spinning activity...please help! I am ready to just buy a new machine
    President:
  • 1,382 Answers
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Posted on Aug 23, 2010
F20 error code on maytag epic any idea what this means?
F20 means that the unit isn't detecting water is entering the machine quick enough. When the error code appears if there is little to no water in the tub, then you have an issue with either the water supply to the washing machine or the electronic water valve. If the washing machine fills up about 1/2 way up the door and is overfilling with the water, it means that your pressure switch is faulty and will need to be replaced because it's not detecting that water is entering the machine.
Mar 02, 2015 | Maytag EPICz 3.7 cu. ft. Washer
Water is not draining or pumped out why ?
Do you have an HE or standard washing machine?
If its not draining on an HE machine you need to check the drainage port on it which is usually on the lower left hand side facing it. Beware there is water that will come out especially if there is water in the machine. There is probably a sock or some other items trapped in there making the drainage slow. The drainage filter on a standard machine varies depending on the brand. Usually they are on the back of your washing machine. I would check the drainage hose and the filter to see if there is any socks or other items stuck in them. That is usually the issue when the water isn't spinning out. Good luck
Nov 21, 2014 | Washing Machines
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
Maytag Epic Z Washer F-20, Water Inlet replaced, still F-20 Error
Chris an F-20 is usually a clogged filter on duet washers. Did you go by the tech sheet in your machine? It gives the codes and remedys and is in a jacket behind the kickplate which you remove to get to the filter. You will need a quarter inch nutdriver to gain access.
SERVICE MANUAL is HERE on my manual page
Dec 07, 2012 | Maytag EPICz Electric Dryer
I have a Maytag EpicZ. It is giving me error code F20. What do I do?
its a reaction code try unplugging the washer for ten minutes then try it again let me know how it goes
merry christmas
Dec 21, 2010 | Maytag Washing Machines
F20
F20 indicates that it is not getting enough water. Check to make sure the hose is not kinked and that the water is turned completely on. If that checks out, turn the water off and disconnect the hose from the machine. Look at the inlet filter and make sure it is clear. If necessary, clean out the debris with a small brush and reattach the hose.
Nov 26, 2010 | Kenmore HE2 Plus Front Load Washer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wd860 code f20
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2009 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
282 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
