Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyo laser 73 error code EE8. What does that mean?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
All error codes are explained on the lower left side of the heater. The EE8 message is for the combustion blower motor. If your stove has been unused for the summer you may get away with just spinning the blower wheel by hand to free it up. If this does not work you are in for a new motor or assembly. Either way you need to clean the blower and heat exchanger.
Tom
Posted on Aug 23, 2010
I have an error code of EE2. The system will not
First- do you have enough fuel.
Does the unit ignite or not
More info would help me
Total Toyo
(907) 488-9179
Dec 15, 2009 | Rinnai Toyostove Direct Vent Heater:...
My laser 73 heater has an error of ee8
Hello
An ee8 message refers to the combustion Blower motor
Unplug unit
Take off front cover
There is a rubber hose from blower case to the base of the unit
Take it off carefuly
Use your finger or a Pencil to try to move the intake fan
Resemble unit
If this doesn't work you may have to replace Blower motor or just clean it up.
If you can't figure it out gimmie a call Total Toyo (907) 488-9179
Dec 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
I need to get replacement parts for my laser 73 stove and no one around seems to carry them? Any ideas?
Any dealer that sells new Toyo stoves should be able to help you.
I don't think the rules of this site will allow me to post the web address of the dealer I use; but typing "Toyotomi heater service" into Google pulled up quite a few dealers.
Hope this helps!
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
We just got oil after not using our toyo stove since last Summer. when I turned it on and push the on button it flashes 12:00 then a second push of on button briefly shows temp then goes to EE8, I can't...
Ok so I bought a L 73 model two years ago and today I had fuel delivered in prep for the winter. When I turned the Toyo on it waited about 5 minutes before giving me an EE 08 error message. The manual showed blower motor trouble and I was bummed so I called a friend. He gave me the following information he learned from a Toyo dealer as a "temp" fix until a more thorough cleaning can take place. Apparently stuff (crusties, ash and burnt debris) have a tendency to build up around the blower motor fan which causes it to get stuck. This is not the large visible fan on the back, but the smaller internal one. There is a rubberized hose leading to the larger fan and a smaller flexible stainless exhaust next to it, which is the one I was told to remove. Once you remove the flexible exhaust get a flashlight and look into the back and you'll see the fan (or only about the 1/3 of it which is visible). Take a pencil eraser and gently remove the build up between the exhaust slats. I also used my craftsman shop vac which fit nicely right over the hole to remove the debris. Once you have all the soot, crusties and stuff removed the fan should be spinning at warp speed when you remove the shop vac. This took my literally about 10 minutes to disconnect, clean and reconnect. About 8-10 minutes later the unit was working great! Hope this helps anyone having similar problems.
Feb 19, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove l73
Remove the front panel. Look for the "L" shaped rubber hose near the bottom that goes to the metal blower box. Remove the end of the hose at the blower box. Inside the opening you can see the blower fan blades. Using a pencil or other slim object, gently rotate the fan while the power is on. The blower should start on its own after you get it going. Let the blower run a few minutes to loosen itself up. Replace the hose and front panel. The blower fan tends to stick if the unit is turned off for long periods of time, such as from Spring until Fall. My Laser 73 blower sticks almost every year and I cure the problem doing the above procedure. HTH
May 01, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo 73 don't work
Take a look at this...
http://www.rural-energy.com/publications/catalog/document/338
This site says there is a problem with the blower motor assembly.
Apr 28, 2008 | Rinnai Toyostove Direct Vent Heater:...
EE2 code for toyo 3
What Does EE2 Mean? Laser 30, 56, and 73 model Laser heaters cease operation and display
the EE2 code on the control panel (instead of the clock or temperature settings) when the primary
flame rod on the heater fails to sense a flame during the first 5 minutes of the Ignition and Pre-
Heat cycle. On the Laser 55 and 72 the heater will stop and the red Reset lamp will light rather
than the EE2 code. (Note: There may be other reasons for the reset lamp to come on but much of
this information will apply.)
What Can Cause An EE2 Error? The primary flame rod is the only sensor in the heater that
can cause the EE2 error. Thus, if it occurs, either there is (1) no flame to detect, or (2) the
sensor failed to detect the flame. The flame rod is located on the lower 1/3 of the burner. It is a
heavy wire with a ceramic insulator. A single white insulated wire connects this device to the
main circuit board.
Dec 12, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
1,469 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
