My honeywell thermostat will not cut on. I have tried reseting all the breakers and still nothing. Please help!
  • 43,501 Answers
If you have no power either the batteries have died or the transformer in the air handler or furnace has died....
Check for 24v AC power at the t-stat and then check to see if it has batteries...
heatman101
Posted on Aug 23, 2010
Honeywell TH9421C1004 blank screen after power outage
We'd love to help resolve this. Please give us a call at 1.855.733.5465 and our customer support team will be happy to troubleshoot with you.
Sep 01, 2014 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Honeywell ac thermostat not working
The replacement batteries may be no good or may have been installed with the wrong polarity. Also, if your Honeywell thermostat latches into a wall mount, you may have reinstalled it incorrectly. I speak from experience
Jun 18, 2013 | Heating & Cooling
My heater are has no heat and i have the problem that i can't swich on any heat so please give any help you can able.
there could be alot of things going on is this gas or electric heat first off? do you have a heat pump system does the outside unit normally run during the winter if so then probley a heat pump...
does the fan come on when you put the thermostat in "fan" position if so ok we got power still to unit... try resetting the breaker first to the heater at electric panel the one marked heat or furnace if not marked go to indoor unit see if it has a plug or breaker on it reset there. try operation again watch it and see what it does if a gas unit there is a series of operation whee does it fail most gas units have a fault light inside you can look at and will help...if electric go back after resetting and try again if nothing remove cover to thermostat do you have good batteries in it if so the take a small wire and jump the terminals "r" and "w" ehich is power adn heat see if it works that way... if nothing then you got an issue with the indoor unit most likely and will need more explanation if it does work then thermostat is either programmed wrong or faulty.. make sure you have it set on hold rather that program... repost if you need more help
Jan 06, 2011 | Honeywell CT3200 5-2 Day Electronic...
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Inside unit running outside want come on temp on
check circuit breaker in house panel labeled a/c or outdoor unit
check box near outdoor unit for a breaker or fuses
some thermostats have a 5 min delay when switched to a/c
check for external reset buttons at outdoor unit some are red depending on brand
check that all wires are intact at outdoor unit------none cut or hanging and not hooked to anything?
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
