Question about Panasonic PT-AE700U Multimedia Projector
PT-AE700U No Power
I have a Panasonic PT-AE700U projector that came on for about 30 seconds and then cut off. It is getting no power. There are no sounds or lights coming on. The projector has had nothing done to it and has been in a stationary position.
  • Anonymous Oct 18, 2008
    I have the same problem. Red power light turns green, green light flickers, flashes a screen image for a second, then shuts off.
  • Anonymous Jan 06, 2009
    My problem is identical to Guest who reported the same fault on Oct 18 2008. Red power light turns green, green light flickers, flashes a screen image for a second, then shuts off. Doesn't sound like fuse as there is some LED activity (power LED only), but am interested to hear if Marrie thinks this is a power supply or a mainboard.
  • 563 Answers
Hi ErnieN008
If there is no LED's flashing or even lighting up for that matter , then it could just be the fuse on the Poersupplyboard that has gone.
You can replace this fuse by opening up the top cover and looking for the board with the AC inlet on it.
If the problem however still exists , you will have to replace the powersupply.
Posted on May 06, 2008
MY PT-AE700U LCD PROJECTOR HAS A BLUE HAZE RUNNING VERTICALLY ON THE LEFT HALF OF THE PICTURE.
Open the upper cover remove screw back side of the projector
Remove LCD connector and clean with soft cloth and fix it again.
close the upper cover and then POWER ON if the problem exist then the blue LCD is faulty and need to be replaced.
(very carefully because the ribbon cables and connector of the LCD is very senstive)
Jan 22, 2011 | Panasonic PT-AE900U Multimedia Projector
PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U
may be a heat problem: check the psu unit for components getting too hot...use a laser thermometer and keep you fingers away from the psu ! other possible problem may be a bad capacitor or the thermal protection before the psu..but this would be a very uncommon problem.
Dec 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Mainboard Replacement for PT AE700U
Hi CFP123
You will have to phone Panasonic for the part - do have the part number on the board handy when phoning in.
As for the pricing it depends on which country you are in , but it's normally between $100 - $150
May 13, 2008 | Panasonic PT-AE700U Multimedia Projector
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Projector
Other than the usual stuff (power cord etc.), check that the lamp cover (not the lens cover) is securely covered. There's a safety mechanism preventing projectors from powering up if it isn't.
Jan 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
370 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
