Question about Samsung BD-P4600 Blu-Ray Player
My blu-ray has become completely unresponsive. It goes back and forth between a "no signal" screen, and a blank screen. Does not respond to "play" "fast forward" or even eject. I must turn the machine off. It has been a slow deterioration, starting with an intermittent unresponsiveness to the remote. The DVD functions fine. I have done all of the updates. I have an internet connection. Any guesses? I would have thought that it was a faulty blu-ray disc, but it happened with the last one too!
SOURCE: I have a Samsung BD-P1000
BD-P1000 Update Solution
The solution that worked for me: I went to www.samsung.com/ca and downloaded the Samsung BD-P1000 player's firmware update to my desktop. When opened, I was directed to"burn" a DVD on my computer. I then inserted the new DVD in my Blu-Ray player. The player automatically checked and confirmed player model number and registration and uploaded information from the DVD and the update was complete. The BD-P1000 then flawlessly played the rented Blu-Ray disc of "The Scorpion King".
Thank You Samsung!
Posted on Nov 27, 2008
  • 10 Answers
SOURCE: The player either freezes completely or pixelates during playback
I think the problem is for this the disc may be damaged. Or dont use copies this freezez and ruines the system, there may be a microchip problem i sugest return it and ask for compesasatin
Posted on Dec 21, 2009
SOURCE: my samsung bd-p1500 blu-ray player won't play
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
Posted on May 10, 2010
SOURCE: My Samsung Blu Ray Player
The CRM codes changed, I was getting this on some new disks, Avatar and the happening.
Upgraded to the latest cod and all is OK again.
Posted on Aug 30, 2010
  • 4 Answers
SOURCE: My samsung blu-ray disc player
http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=BD-P1500%2FXSA&prd_mdl_name=BD-P1500&prd_ia_sub_class_cd=P
OR GO TO
www.samsung.com click Support then Downloads and enter your model number. There's instructions for downloading firmware and loading via usb stick or cd.
Hope this helps!
Posted on Sep 20, 2010
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(the BD player was completely unresponsive) I had to unplug it to power it off for awhile. Then I tried watching Netflix and It...
There should be an option in your setup menu to perform a reset. Reset all settings to factory defaults and try it then. This will sometime sfix this problem. If not, then you are looking at a really expensive replacement main board that will cost you more than the unit is worth
Mar 25, 2015 | Sony Televison & Video
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(was completely unresponsive. I had to unplug it to power it off for awhile. It worked for a few minutes and then started...
Does the player work with other blurry discs? If so, then your new- used disc has issues. You can try cleaning the disc or buy a repair kit.
If that doesn’t work you can try a different player.
Nov 13, 2017 | Sony Televison & Video
Sony bdp-bx57 signal cuts out
test the connection see the diagram attached. Clean the contacts and connector with contacts cleaner.180f246a-cc1f-493b-9d8e-3abff472975f.jpega07d2d96-4cdd-4858-8bc3-356bb92dae0b.gif
However you can restore in the menu to factory default.and see what happen.
Jul 13, 2013 | Sony BDP-BX57 Blu-Ray Player
My vizio vbr120 will play dvd but not blu ray
This is a common problem in blu ray discs, the reason why it won't play is because they play at a faster speed and demand a higher precision to produce the high definition signal required to play the program. The only way to fix this is to replace the whole laser pickup assembly which would not be cost effective.
Apr 21, 2012 | Vizio VBR120 Player
Sony Blu Ray S350 plays well but have intermittent loss of video signal. Screen shows coloured background (yellow or white), audio continues to play then screen goes black then picture returns; this cycle...
It may be a problem in the digital section of the TV. If you find a part of the movie that blanks out, try rewinding back to it and see if it goes out again. It may also be the HDMI cable you are using. The blank out is often the result of the TV trying to adjust to the correct resolution for the program being played, and we need to diagnose why it is changing resolutions. Microwave interference and voltage fluctuations can also cause these issues.
Feb 25, 2011 | Sony BDP-S350 Blu-Ray Player
My tv screen goes blank for several seconds while I am playing tapes
Mine does that too when playing VHS. But play any dvd and switch back to vhs and the black screen goes away
Nov 15, 2010 | Toshiba DVR3 DVD Recorder/VCR
My ps3 turns on and off ok, plays movies off the hard drive and will play ps3 games but has suddenly stopped playing movies ( dvd & blu ray ) it recognises the disc and goes to play it but the screen...
That is actually a poor conclusion. There are three different lasers, one for blu-ray, one DVD and one for CD games all in one holder inside. It certainly CAN be the laser. The description id the DVD/Blu-ray part is having focus problems. Contact Sony for a service center that can install a new drive (It needs to be calibrated on install)
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Wont play dvd's or blue rays but will play games
sounds like the lens servo my be ought , this is the small motor that ajust the lens between playing a game, movie, or blu-ray
May 29, 2009 | Sony Playstation 3 (PS3) Console
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Samsung BD-P4600  Blu-Ray Player Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
