Question about Sanyo DS24425 24" TV
Tv not working .i tried un plugging. does not click or anything. ihad similar problem before they replaced tv . is this common?
  • kiz1972 Jun 28, 2008
    missing part of chassis AC6A1 sanyo
  • ecalvin456 Jul 04, 2008
    tv not working. I tried to unplug it and still not working. will not come on at all
  • 30 Answers
I have a sanyo 24" TV that turns on but no video and very weak sound. I turned up screen control on the flyback. No affect on the screen
Posted on Aug 02, 2008
Buy a new one...
Posted on Jun 17, 2008
  • 3 Answers
It is not common , you must check your sockets where you have plug your tv. there are maybe loose connections!!
Posted on May 06, 2008
Samsung RS2530BWP side by side - compressor not running.
sounds like it is tripping on a thermal cut out you need to check ohm values on compressor common pin to left pin value plus common pin to right pin value should equal left pin to right pin value else one of the motors inside compressor is knackered
Dec 19, 2012 | Refrigerators
Ihad to replace the ABS unit & the abslight is still on what do I do
Could it be you just had a cheap wheel ABS sensor bad or needed cleaning. Un plug and take an ohm reading they should all be the same
Dec 07, 2011 | 1997 Jeep Grand Cherokee
Vertical lines of lcd
There is an issue with the logic control board. If it is under warrantee, take it back. Otherwise if off warrantee try this procedures - (1)UN plug every thing off the TV instep for the power plug than un plug the power from the wall than hold down the? power button for 30seconds than plug every thing back in (2) subout the power and VGA cables as a test to make sure not a cable issue. (3) Remove anything that may be causing electromagnetic interference like a stereo - console TV or other high power source or emitting source like cordless phones etc.. Note that if a desktop pc, then verify your video card fan is working if it has one...if it is overheating, that can cause anomolies.
Jun 13, 2011 | Acer V193w LCD Monitor
Get signal from tv that lamp is not working, been having an intermittent problem with it. What Ive done in the past is pull lamp and reset and it works, this time it doesnt want to come back up. The lamp...
hey there it sounds like you have a issue with the ballast board this is a common problem with this DLP TV's check out this link
http://www.fixya.com/support/r3556856-how_to_know_if_it_is_the_lamp_or_ballast
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 27, 2010 | Toshiba 56HM66 56" Projection HDTV
LCD tv zoomed in. can't un-zoom it. tried restoring to factory settings, nothing. tried settings couldn't find anything that led me to undo this. just bought this tv. the picture is killer. untill it...
Are you connected to a cable box with its own remote control, if so, some systems have a zoom control on the cable box remote. Check to see if it is setup to "Movie" mode or similar.
Dec 27, 2009 | Televison & Video
Ps3 not booting up
Un-plug the PS3 then leave it with no power over night. plug it back in and it should work.
Hope this works,
Luke Wilcox
10 yr old kid that knows alot about electronics
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
Screen projector un aligned
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
TV won't turn on
remove all the external connections connected to the tv.then un plug the tv wire from the power outlet.then after some time just plug only the tv wire back in the power outlet.do not connect the other devices and check if the tv is working as normal or not.if it does not works then
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
also check for any loose soldering joints on the power supply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
Oct 13, 2008 | Sony Televison & Video
"TV Not Turning On"
Hey im not one of the techy guys with tv's im a computer guy.
but i have that same pioneer set you have the 510-HD and i had a similar if not the same problem.
my ex-father in law is a tv repair guy he told me to resolder the power board connections that looked corroded. i did just that and problem solved. hope this helps you out
FYI make sure you use rosin core solder not acid core good luck
Nov 27, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Sanyo DS24425 24" TV Logo
95 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
