Question about Karcher K2.26 Electric Power Washer
Karcher K2.26M electric power washer leaks water around the on/off switch and around bottom of unit. low pressure.
    Problem Solver:
  • 18 Answers
Probably your seals are bad and they are leakyng
Posted on Aug 25, 2010
Its leaking water
Take it out of case
Connect to hose. Turn on tap & see were the leek is.
Jun 14, 2015 | Karcher 16016080 K2 26 1600 PSI Electric...
Water leaking
Cracked casing or blown gasket due to freezing and not draining the pump.
Apr 22, 2014 | Karcher K2.26 Electric Power Washer
Water is leaking from the bottom of washer mower is running and some water is coming out
ive seen this before, lots of people dont clean out there power washers when not in use, hard water build up is a big problem in these units witch cause the pump not to surge correctly, you should get it serviced, thankx
Apr 18, 2011 | Karcher K2.26 Electric Power Washer
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
My Karcher (K2.26M) pressure washer is leaking water from the ON/OFF switch and the bottom. Does anyone know what could have broken, and what part I would need to fix it?
I have had a dozen of these units, My advice is not to bother trying to get parts or fix it. Its designed to be a throw away unit!
Oct 31, 2009 | Karcher K2.26 Electric Power Washer
I have a Karcher K3.48M electric pressure washer which used to shut off when you weren't using the cleaning wand. This no longer happens and there is alot of water running out of the bottom of the unit....
hi you will have a 8 digit number on a silver plate on the machine with a number like 1.141-470.0
Then go to www.karcher.com then on the left click on Europe, then you will see International,on the left again you will see service click on that, then click on spare parts. you will see a box to enter the model or better still the 8 digit number. then tick on, i am aware parts should be fited by a trained enginner,always choose the largest pdf file, parts always same number in all countrys. hope that will help.
parts for karcher @ Q Services 07970636222 ring
Oct 18, 2009 | Karcher PSI Electric Pressure Washer
Karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Jun 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher electric power washer is leaking out of the bottom
where is the leak coming from inside? inlet side of high pressure side
Jun 08, 2009 | Karcher PSI Electric Pressure Washer
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K2.26 Electric Power Washer Logo
421 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
