Question about HP Compaq Presario SR2150NX PC Desktop
How do you uninstall the HP Photosmart printer? I tried using the uninstall from the start menu but it doesn't work.
  • HP Master
  • 8,404 Answers
Go to the Control Panel, select the printer folder ... right click the printer you want to delete ... pick delete.
Posted on Aug 23, 2010
My scanner stopped working. hp solution center says that the device installation is not complete. i have a hp photosmart 3210 all in one. it was working the last time i used the scanner.
You probably need to uninstall and re-install the Latest Drivers for your printer
To uninstall you can do it from the Software disk you recieved with printer.
Insert the Disk in CD ROM and Click uninstall from HP Printer Menu
OR If you dont have the disk, you need to manually uninstall the Software
( Disconnect the USB cord before uninstalling )
Click START - Open Control panel - Add/remove Programs ( XP ) / Or Programs and FEatures ( Vista/Win 7 )
you will find list of HP Programs installed..
Choose one by one and uninstall these programs
1. HP Customer participation program
2. HP Imaging Device and software
3. Software and drivers for Photosmart 3200
4. HP Solution Center or HP Director
5. HP Image Zone ( or Image Zone Express / HP Photosmart Essential )
6. HP Update
7. HP Printer Drivers/Diagnostic Drivers
( after every Uninstall you will be prompted to restart the PC, you will find an option [ Click here to restart later ]. click on it and restart the PC once you completed uninstalling all the above programs )
Once you have uninstalled - click on this link to download the latest drivers by choosing your operating system
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=439488&lc=en&cc=us&dlc=en&lang=en&cc=us
Save this File on Desktop an run it
Jun 16, 2010 | HP Photosmart 3210 Printer
My HP 2410 Photosmart printer is making a clicking nose on start up. In the past I was instructed to unplug it and everything attached to it, including the computer, for 15-30 minutes and it would reset...
Uninstall the printer completely starting from the software.
Go to Start Menu, Control Panel, Add/Remove Programs, select the HP Photosmart software and remove it.
Then, go to Start Menu, Control Panel, Device Manager (usually under Administrative Tools/Computer Management).
Select under "Printers", the HP Photosmart 2410 All-in-One InkJet Printer and remove it.
Restart your computer and follow the instructions from your HP manual to setup your printer again.
Apr 06, 2010 | HP Photosmart 2410 All-In-One InkJet...
Photosmart C7250 All-in-One. Copier, fax and printer work. But I cannot find my scanner icon where it was on my previous computer.
Were you able to install the correct driver for your OS? Usually the scanner application can be found in the list of Programs >> HP Photosmar C7250. If what you are referring to is the icon on your System Tray (lower right corner), you can always add an icon there by right clicking the blank space in your system tray and choose properties. On the taskbar tab, click on Customize, look for the icon for your scanner, click for the behavior and from the drop down button, choose "Always show".
Try to scan also by pressing the scan button in your printer and press start to initiate a scan.
Jan 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
Just installed my HP photosmart C5180 all in one, I connected threw a USB I have uninstalled then reinstalled. Same problem scanner and copier does not work. there is a screen that said there is a DDE...
I would search for latest drivers for the photosmart and download them. Than turn on machine before connecting to computer.
Also you should go to control panel, printers, and see if your machine is listed there and set as default printing device.
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
'Fatal communication error' - cannot print
My first recommendation is to carry a printer self test. Use the Menu on the front panel to do this ok. If both printers succeed in self test then the problem is reduced. Uninstall the previous drivers for these printers. Connect the printer data cable(USB) to the pc and check for communication. that is, whether or not it is detected by the pc's OS. This should be done one after the other on different ports. If the two printers are attached to same pc, I recommend you use a combination of USB and Parallel printer cables. If communication is successful then detach both cables from the pc. Install the drivers for the USB printer without attaching it to the pc. Then attach when prompted. That way, the printer is guaranteed. For the printer on the parallel port, connect it and install the drivers while attached to the pc. If nothing happens still, you should consider leaving only a printer on the pc. Good luck
May 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can't scan to computer
I am not an expert, only a c7280 user. I use my printer wirelessly and was having problem scanning when using the controls directly on the printer (scan menu). By trial and error, I tried scanning by going to HP solution center on my computer and just followed the directions from the scan menu. That worked. If you can print wirelessly, you can scan wirelessly. I agree the HP support is a huge waste of time. I only get mad talking to them.
Apr 16, 2009 | HP Photosmart C7280 Printer
How can I uninstall Adobe album starter edition 3.2
try to run at the startup configuration and disable the program then restart, What Operationg System do you used?
Feb 15, 2009 | HP Photosmart 3210 Printer
Can't scan from HP Photosmart C7280 to my Mac Computer
The best way to scan documents from the scanner to your computer is to use HP Photosmart Essential. If you don`t already have it installed it can be downloaded from the HP site. Once in the program it is very simple to follow. It is basically a point and click operation.
Let me know how you make out and we can do other things if this doesn`t work for you.
Please remember to rate me.
Feb 02, 2009 | HP PSC 2410 All-In-One InkJet Printer
Installation Problems, Please help!
try downloading the software from the HP website and then reinstall the printer. But also try to uninstall it using control panel add/remove programs, restart your computer, and then reinstall using the downloaded driver.
Jan 27, 2008 | HP Photosmart C4280 Aio Printer
HP Compaq Presario SR2150NX PC Desktop Logo
18 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
