Question about HP Compaq Presario SR2150NX PC Desktop
What memory is required in order to upgrade to 1G ram?
    Guru:
  • 1,082 Answers
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot or 2 GB total. You'll have to remove one slot of memory to install new. Memory is around $40 per gig.
Posted on Aug 23, 2010
  • 490 Answers
Here is the url to Crucial memory's website with the product you requested. Happy upgrading:)
http://www.crucial.com/store/listparts.aspx?model=Presario%20SR2150NX
I have a LGX11 network for many years, and now I need to add RAM to upgrade from XP to WINDOW7. Can I do that?
Unfortunately, the memory on this particular net book is soldered directly onto the main board instead of the removable type so the RAM is not user upgradeable.
Mar 27, 2014 | Computers & Internet
I am upgrading to windows 7. How much memory should go with the up grade? at present time I have1028 and512 GB installed. CPU ok for the up grade?
minimum 2GB for smooth use of the pc, but RAM is fairly cheep so I would go for 4GB. The most importet hardware to be fast is your harddrive.
Mar 26, 2011 | EliteGroup KM400-M2 Motherboard
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
I want to upgrade my extenza from 1g to 2g or more how can i do on my own way, where we can find the memory slot.
its located underneath the laptop should be 1-2 phillips screws the ram sticks are inside push the tabs on the end's of the ram sticks they will pop up on a 45 degree angle remove them and replace with the amount you require if only adding 1 stick with an exsisting stick make sure to match ram speeds for better performance good luck
Nov 18, 2010 | Acer Extensa 4620 Notebook
Information on what type of memory upgrade device
Standard Memory: 512 MB - (MegaByte)
Approximately 1 million bytes','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>MB
(Removable)
Maximum Memory: 2 GB - (GigaByte)
Approximately 1 billion bytes, or exactly 1 byte x 1,0243. (1,073,741,824) bytes.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>GB
Expansion: 2 Sockets
CPU & ChipSet: AMD Sempron
Bus Architecture: PCI; USB - (Universal Serial Bus)
Standard connection for peripherals such as digital cameras, scanners, printers etc. Allows for quick and easy data transfer. Uses the plug and play facility available with Windows 98 / ME / 2000 XP or Macs.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>USB
Mfgr's System P/N's: N/A
Comments MODULES MUST BE ORDERED AND INSTALLED IN PAIRS for Dual Channel.
KVR400X64C3A/512
KVR400X64C3A/1G
KVR400X64C3AK2/1G
KVR400X64C3AK2/2G
Jul 22, 2010 | E-Machines eMachines Desktop PC
Hi! How can I increase the RAM on my Aspire T310? Can I do it myself? Thanks.
Yes, you can definitely do this yourself. Upgrading RAM is one thing that repair places make much money; however, it takes a matter of seconds to complete.
Your Acer Aspire T310 has two memory slots on the motherboard. Each slot can hold a maximum of 1GB each for a total of 2GB RAM. You should see a great improvement in performance.
To save on a long tutorial, I have included a video link. The type of RAM you need can be found at the following link. Kingston is another manufacturer you could check into also.
Please remember to unplug all cords from your computer and be in a static free environment before upgrading your memory. Good Luck!
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=269237BDA5CA7304
Feb 26, 2010 | Acer Aspire T310 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
What is the optium ram upgrade for a lenovo 3000 y410
DDR2-PC5300, and the max it will accommodate is 2GB (2 x 1GB).
Hope this helps you
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Memory upgrade
It looks like the A25 will only hold 1g of PC2100, which is really plenty, unless you're a serious gamer or into graphic arts and need an extreme high definition video. Here's a link to the memory configurator that I use in order to find the proper memory, max held, and the chipset. You might double check to be sure I looked up the right machine. If it is the right machine, I suggest two 512mb chips. Sometimes you can't run one 1g chip because the slots are designed to only hold a certain amount, and if they will hold the 1g chip, sometime the machine doesn't run properly. It wants to use both slots accordingly, running only one creates conflicts. This should help in boosting your RAM.
Aug 26, 2008 | Toshiba Satellite A25-S207 Notebook
IBM thinkpad g40..i want to upgrade
To upgrade your CD drive there is a screw on the bottom of the machine that holds it in place. Remove this screw and the drive will slide out. I buy most drives for my customers and shop from Ebay. I've found that there are some very good vendors with good prices and warranties there. Now for the memory. The memory you need for your machine is PC2100, and 1g is the max. I mainly use Kingston or Infiniton. Both of these are good chips, and there are other good chips out there. I suggest that you use two 512mb chips that are the same make. I've found that sometimes two different chips will create a conflict with each other. The memory is located under a panel on the bottom of the machine. For memory I use pricewatch.com If you have any other questions please fell free to ask.
Jul 21, 2008 | IBM ThinkPad G40 Notebook
HP Compaq Presario SR2150NX PC Desktop Logo
112 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
