Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Timing is off nedd to know what depth to set magneto at briggs and stratton 600 series lawn mower 190cc
    Champion:
  • 225 Answers
The timing is fixed by way of woodruff key in the crank which locates into a chanel in the flywheel and is not adjustable. If you mean the air gap between the ignition unit and flywheel then set it to aprox .002-.005 inch
Posted on Mar 07, 2015
  • 79 Answers
SOURCE: 190cc 3in1 briggs and stratton mower wont start...
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Posted on Apr 25, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
  • 407 Answers
SOURCE: unable to locate oil drain
Open the spot where you put the oil in.Now turn the mower so that is comes out the hole it went in.It can be messy so use a large bucket.
Posted on May 30, 2011
rycgl
  • 1545 Answers
SOURCE: What is the magneto gap for a 6HP Briggs &
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Posted on Jun 10, 2011
How much oil does a 675 briggs & stratton 22" lawn mower take?
HI There try adding oil a bit at a time. They will only need minimum amount to lubricate the engine. Firstly put in about a quarter of a litre and check the dip stick after 10 mins.
Sep 23, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Change oil on 190cc 875 briggs stratton
i just tip mine over and catch it into a can out of the dip stick hole
Mar 27, 2012 | Briggs & Stratton 190cc 875 Series OHV...
875 Series Engine-cleaned flywheel and magnets and magneto. Put back together and now no spark to spark plug. What is the air gap between the magneto and flywheel.
You should put it at .020
Are you sure you had spark before you took it apart? If you are not sure, then the Ignition Coil may have went bad. How did it act before you decided to take it apart?
Jim
Aug 17, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Gap setting for briggs-stratton 6.5 lawn mower
I believe it is 0.040 on a regular spark plug gapper
Nov 07, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
May 31, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
190cc 3in1 briggs and stratton mower wont start... new plug and good spark..any ideas..
Apr 24, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
185 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
