Question about Car Audio & Video
How to install a tsunami 2 farad triangle capacitor
  • 78 Answers
SOURCE: need installation advice
All caps are designed to be wired in parallel with another cap if desired. The three openings work to daisychain caps, positive to positive and neg to neg, the third connects to ground on the negative side and 12v+ on positive. You do not want to ground multipule caps individually. You can add as many caps as you can afford!
Posted on Jul 08, 2009
  • 67 Answers
SOURCE: 1 amp cuts off
u need more capanice general fourmla 100watts 4 .5 farad or run 2 car batt in should fix problem parleell
Posted on Aug 08, 2009
Bennytechkid
  • 99 Answers
SOURCE: diamond wire diagrams for capacitors 3 0 farad
i think you mean you want to know how to wire 2x 3.0 farad 12V capacitors into a 24V truck??????? let me know i can help with this,ben
Posted on Aug 13, 2009
etirbynnor
  • 655 Answers
SOURCE: Need diagram to install capacitor
Hello tommysgirl,
Here's a link to Car Audio Help's cap wiring diagram.
Hope this helps.
Posted on Aug 28, 2009
  • 8 Answers
SOURCE: need wiring diagram for tsunami
After a bit of searching I found the instruction manual:
http://a248.e.akamai.net/pix.crutchfield.com/manuals/120/120pp912u.pdf
Hope it helps.
Posted on Mar 05, 2011
What are the causes of tsunami
Usually caused by an under sea earthquake.
Check out this WEB site for details.
http://wiki.answers.com/Q/What_causes_a_tsunami
Feb 14, 2013 | Tsunami Lite Wave Capacitor 2.0-farad with...
Need wiring diagram for tsunami 1.2 farad capacitor cap.
Hope it helps.
Mar 05, 2011 | Metra Tsunami 1.2 Farad Capacitor
I have a 1200 watt amp and 2 12 in pioneer champions and it keeps killing my battery how do I hook up this capasitor I just bought?
first make sure your power wire is directly hooked to the battery, {make sure ure in line fuse is pulled} power wire that goes to positive of power cap , ground wire is grounded to chasis, now attach aditional power wire to amp and aditonal grond to amp . make sure all conections are solid and tight { also make sure inside of power cap is tight as well after long periods of time the insides loosen } i have 2 -1,000 watt sony xploid amps and 2- 1,200 watt sony expoid subs and they pound hard . i probley should have 2-1.2 farrid caps for what i have but it seems that its holding its own
Dec 04, 2010 | Metra Tsunami 1.2 Farad Capacitor
Do you have wiring guide for the 2.0 capacitor
audiobahn.com can give you a free wiring diagram on this, go to tech support and click on the wiring diagram
Apr 26, 2010 | Tsunami Lite Wave Capacitor 2.0-farad with...
The voltage meter stays on an there is a flashin blud led light every 3 to 5 second only flashin 2 to 3 times a cycle, having problems with running battery down also, brand new battery too? would having it...
the LCD meter will stay on until voltage in the car stabilizes, and you will notice that if u hit the power unlock button it will turn back on after its off..
do you have it hooked up correctly?
I Usually run power from battery to + of capacitor then another wire from positive of capacitor to amp, Then you can run ground from amp to capacitor negative then anotheer wire from cap - to a good ground
Mar 30, 2010 | Tsunami Lite Wave Capacitor 2.0-farad with...
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
1 amp cuts off
i had this same prob. & i run 2 amps as well, cameto find out i had a neg. & positive touching , so check all ur wiring for tht amp..
Apr 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
I was given a tsuname 2 farad
It doesn't matter...Just make sure your negative and positive terminal hookeups are correct. (as in, don't connect a positive wire to a negative terminal).
Mar 22, 2009 | Tsunami Lite Wave Capacitor 2.0-farad with...
Car Audio & Video Logo
186 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
