Question about Lexmark E340 Laser Printer
I have a lexmark e340 and the paper jams and the dislay asks me to remove the back door and the paper and it also does not print and i have changed de cartdriges
    Sergeant:
    Champion:
  • 387 Answers
If you check the feeder and the paper exit and its clean
its possible that you have some paper stuck on the fuser
the fuser is the thermal unit you need to open the top and back cover to get access to the fuser
Posted on Aug 23, 2010
My lexmark E340 printer displays the message: "remove cartridge paper jam" continuously and not print more pages
There is probably a sensor that is being blocked by paper that you might not be able to see easily. Remove cartridge and check the inside of the printer with a flashlight. Please turn off printer before doing this.
Sep 06, 2013 | Lexmark E230, E232, E234, E238, E240,...
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
The paper is jamed in the back and I can't find a way to release it. Lexmark E340
jammed in fuser which is in the back to get to fuser remove rear door remove redrive two screws you will see the fuse be carful output sensor in middle of fuser just pull it gently if it jams again may need a new fuser
Sep 08, 2011 | Lexmark E340 Laser Printer
202 papier vast open both doors from the lexmark e340 printer
Please click on the link below to resolve paper jam problems. To prevent paper jams, please make sure that the paper settings on the printer is in sync from the application (e.g Microsoft word).
http://bitly.com/pbUgyr
If you need further assistance please contact Lexmark Technical Support.
Jul 27, 2011 | Lexmark E340 Laser Printer
Lexmark E342n. The paper jams after it prints and before ejecting. Paper is not wringled when pulled out. I open the back door and the end is there. It is like it is using shorter paper then letter.
Power off the printer, check the entire paper path of the printer for any jammed sheets of paper or other obstructions. Remove any obstructions you find and try printing again. Check if the page setting may be incorrect or paper size and the paper size settings do not match and make sure that the paper size in the printer driver settings matches the paper in the tray.
For further assistance, please contact Lexmark Technical Support.
Jan 07, 2011 | Lexmark E342n Laser Printer
I have a paper jam in my E240 Lesmark printer.. A sheet of paper is stuck on its way to being fed out of the printer, at its top and back. On the front, the sign indicating that more paper is needed is lit...
Here's an article on How to Clear Paper Jams on a Lexmark E238, E240, E240n, E340, E342n Printer. Just click on this link: http://bit.ly/cBXKAL. This might give you an idea on what to do when having a paper jam problem on the printer. If you need further assistance, don't hesitate to contact Lexmark technical support or call your authorized service provider.
Aug 27, 2010 | Lexmark C533DN InkJet Printer
Printer Jam dislay. Paper removed still
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Brother MFC 240C All-In-One InkJet Printer
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
I keep getting message of paper jam.
Basically it should look like it is touching the upper roller, the gap should be a small one it it barely sticks out it is broken and the paper is not being detected as going trough the fuser.
Oct 31, 2008 | Lexmark E340 Laser Printer
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
Lexmark E340 Laser Printer Logo
279 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
