Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Ice maker GCD-23 will not push out the ice cubes
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
WCAnderson
  • 9 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Unfortunately, this is one of the inherent problems with a self defrosting freezer units. Some frost free models/brands are less smelly than others. Grabbing the cubes as soon as they drop so they don't sit in that nasty freezer air and placing them in a zip lock would help a lot but probably not completely. Be sure and clean the inside of the freezer often so there is less of the smell left in the plastic that surrounds the ice cubes as well as the foods. Don't eat freezer burned vanilla ice cream, for sure! Hope this helps.
Posted on Oct 11, 2008
farfield
  • 462 Answers
SOURCE: Top freezer food gets freezer burn fast and now ice cubes and ice
Your discribing 2 opposite symptoms. But 1 thing may be causing both. first thing I think of is a defective defrost heater safety switch. It allowes the food -and freezer compartment to become too warm during defrost. This allowes the food to un freeze. then when defrost is terminated the temp goes back under freezing til the next defrost. 3 to 5 cycles like this and yes you could ahve freezer burn and icecream melting. DOes the ice cream refreeze too? If so you have to remove the freezer pannel covering the evaporastor coil inside the freezer. Locate the defrost safety.
1 of 3 kinds 2 opf these are b8-metal switches and are round and of these 2 kinds 1 is about nickel size and the other is about quarter size and both are round and can be attached to the coil tubing or the freezer wall. Usually these 2 kinds are on Refg/Freezers with no electronics on the door or thermostat.
If you have an Led or LCD display you ahve electronic controls and in most cases have an electronic thermisitor about 1" long and 1/4 to 3/8 inch dia and insulated and attached to the freezer coil line leaving the freezer or on one of the U bends of the coil. It may be attached with a plastic wire tie. (The tie could be broken but this is doubtful from discription).
1st freezer burn is usually caused by drying out of the food while still frozen. And this is why your case is so interesting by doing it so quickly. In all cases 1 the food is not in air tight containers. And the water in the food is being drawn out of it.
Posted on May 08, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
woodchuck789
  • 4059 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
Samsung refrigerator ice maker
Many icemakers use a bar or a sensor to shut off water when ice levels are at a maximum. Check to see if it's bent, missing, or pushed down below the ice level, tricking it into thinking there's no ice there.
Aug 03, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Ice maker make ice but not come out
Hi there! If the ice maker is making ice properly but is not pushing it through tot he bucket or to the door dispenser, it is clogged somewhere. This could be from melted ice cubes blocking the pathway or even a faulty switch arm (or auger) that pushes the ice cubes forward. Check those areas and let me know if you find anything additional or out of place. Also check for any cracks in the ice maker housing.
Mar 31, 2013 | Frigidaire FRS3R5EMB Side by Side...
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
419 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
