Question about Refrigerators
Water in botem of crisper - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 23, 2010
Vegetable crisper is filling with water
You may have have your freezer drain stopped up and when it goes into defrost, it melts and the water spills over to the lower section being the crisper. This is a simple fix. You just need to find out where the water is coming from .
Feb 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Kenmore model 253.7419240p water pooling under crisper
Do you see any ice buildup on or behind the back freezer wall?
Oct 31, 2012 | Kenmore Refrigerators
Water in Crisper, what causes it?
clean out the drain hole in the back so that the water can drain out side into the container on the compressor
make sure that the door seals are intact
Sep 09, 2017 | Samsung RF217ACWP - 20 cu. ft. French Door...
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Does this model have 2 elements? if so why does the botem element has wires giong to it and the top one doesnt?
some of these units could be ordered with one 6000 watt element, but if yours came with two than someone has took one of the thermostats and wires off
Dec 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
