How to get the ratio of 64? - Computers & Internet
  • 7,993 Answers
By definition a ratio is a division of two quantities. To get the ratio of 64 you must specify with respect to what other quantity.
Just to let you know that you question is INCOMPLETE.
Posted on Aug 23, 2010
  • k24674 Aug 23, 2010
    OOPS
    your question is INCOMPLETE.
What screen comes in a toshiba satelite l755-s5216?
"The screen is a 15.6? diagonal widescreen TruBrite TFT display with a native resolution of 1366×768. This display is LED backlit and a 16:9 aspect ratio."
(Driving this display is the Mobile Intel HD graphics chip. It supports 64-1696MB of shared video memory. This is not the card to play video games with.")
From: http://www.bbspot.com/reviews/toshiba-satellite-l755-s5216-laptop-with-intel-pentium
Apr 29, 2014 | Toshiba Satellite L755-s5216 Laptop Screen...
How to simplify ratios
In this case the easiest way is to multiply both sides by 10 to get 144:64, then factor out the largest common denominator (16) to get 9:4.
Nov 21, 2013 | Office Equipment & Supplies
Winzip 17.0 activation code
Its illegal for anyone to provide serial keys for programs that have a retail value set on them.
There are freeware alternatives
7-Zip 9.22 Beta (64-bit)
7-Zip.org - 1.38MB (Open Source) 7-Zip is a file archiver with a high compression ratio.
Dec 11, 2012 | WinZip 12.0 - Windows for PC
Small screen when opening games in windows 7 64 bit . have updated drivers and changed screen resolution - nothing helps, and its all games thats not fullscreen. System is a Aspire 4738ZG 14 inch...
If you were to reduce the screen resolution to the recomended for the game, it should fill the screen depending on what aspect ratio the game is. The higher the resolution the smaller the picture.
Hope that helps.
Feb 27, 2011 | Computers & Internet
I'm trying to connect my n64 up to my LCD HDTV but the visuals are blurry. Other then connecting it up to sn old CRT tv what can I do?
you should go into your display settings on your tv and change the aspect ratio until the picture clears.
Feb 25, 2011 | Nintendo 64 Console
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
Honda accord incorrect gear ratio code p0370
Honda P0370 - Timing Reference High Resolution Signal A Malfunction.
The optical sensor provides a high resolution signal to the Powertrain Control Module (PCM) by counting pulses on the sensor disk located in the injection pump. The high resolution is one of the most important inputs by the PCM for fuel control and timing. This test monitors the number of high resolution pulses which have been missed (not detected). It's based on a comparison between the number of pulses that were detected since the last pump cam pulse and the number of the pulses that should have occurred. There are approximately 64 high resolution pulses for every cam pulse.
Possible Causes:
- Open or short in the optical sensor circuit
- Optical sensor connector
- Damaged optical sensor
- Damaged PCM
- Damaged ECM
Possible Solutions:
- If damaged repair the optical sensor circuit
- Replace optical sensor
- Replace PCM
- Replace ECM
Not sure where you got incorrect gear ratio. This P0370 DTC is for what I have listed above.
Jan 19, 2011 | 1998 Honda Accord
94 caprice classic rear spider gears shot 12 or 16 possi what other rear ends are compatible for this 5.7 liter
. Axle Code >>>>>>>>>>>Standard
2YN Gear Ratio >>>>2.56<<<<< Ring Gear Diameter 8.5 Standard 2GA Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GB Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GH Gear Ratio 2.73 Ring Gear Diameter 8.5 Standard 2LW Gear Ratio 3.08 Ring Gear Diameter 8.5 Standard 2LR Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LY Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LT Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 6YF Gear Ratio 3.23 Ring Gear Diameter 8.5
Axle Code>>>>>>>>> Limited Slip
2LQ Gear Ratio >>>>>>>>2.93<<<<<<<<<<< Ring Gear Diameter 8.5 Limited Slip 2YG Gear Ratio 2.93 Ring Gear Diameter 8.5 Limited Slip 2LX Gear Ratio 3.08 Ring Gear Diameter 8.5 Limited Slip 2ND Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LZ Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LS Gear Ratio 3.23 Ring Gear Diameter 8.5
Nov 28, 2010 | 1994 Chevrolet Caprice Classic
How to calculate ratio number
Ratios are usually written as xx/1 such as 8 to 1 or 4 to 1 so that one is the base number. If you have 8 black sheep out of 64 then it's ration is 64/8 but you want to reduce the 8 to 1 so divide 8 by 8=1. now you have to do the same thing to the the other side of the equation so you have to divide 64 by 8 = 8 or to simplify this divide the first number by the last = the radio. Thus 64/8 = 8/1 on a more difficult scale let's do 6888/123 is 6888 divided by 123 or 56 to 1
Dec 07, 2009 | Computers & Internet
Desktop screen is stretched abnormally
Heres how to change you screen resolution in Vista:
http://www.worldstart.com/tips/tips.php/64
And here for XP:
http://www.microsoft.com/enable/training/windowsxp/screenresolution.aspx
Due to the fact that your device has a Wide-screen monitor. you will have to choose the sizes in between the standard ratio. Here's list depending on if your device is 16:9 or 16:10 as well as standard ratio's:
http://www.freakygaming.com/tutorials/4_3_and_widescreen_resolution_lists.html
Hope this information was helpful.
Apr 26, 2009 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
