Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a Whirlpool Refrigerator model number ED5GHGXMBOO. I have just hooked it up. I have the water line hooked up but it is not making any ice. Is there an adapter or something that i will need to purchase in order for it to work? The water line works with no problem. Thanks
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
lojacksdad
  • 121 Answers
SOURCE: Whirlpool refrigerator/freezer combo with ice
sounds like there is a kink in the supply line
Posted on Apr 22, 2009
  • 351 Answers
SOURCE: Ice maker won't make ice on Whirlpool refrigerator
you most likely need to change the head of thie ice maker or just get a new one... very common
Posted on Jun 24, 2009
SOURCE: ice maker stopped making ice. water works fine
chande the filter
Posted on Jul 12, 2009
Whirlpool ice maker just making thin slabs of ice
What is the model number of your refrigerator this problem is usually caused by inefficient water supply to the ice maker on a whirlpool icemaker the fill valve seals for 7.5 seconds if the water flow is obstructed T-valve that are not recommended for refrigerator water supply lines the next problem could be your water control valve or the filters are clogged restricting water flow here's a short video
Appliance 911 Sea Breeze
Dec 04, 2015 | Whirlpool Refrigerators
Ice maker has stopped making ice
most likely a bad water inlet valve located in the back of the ref where the water line hooks up at
Nov 18, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker water inlet keeps freezing
This problem is caused from a bad water valve. The water line that connects to your refrigerator hooks up directly into your water valve. The way it works is this. The water valve keeps the water pressure to OFF. Whenever your ice maker needs water it simply asks the valve to open and it does. The problem is this. The valve has malfunctioned and isn't totally shutting off anymore. This lets a tiny bit of water through. This water slowly makes its way up the water line into the freezer where it freezes in your tube :) You just need a water valve! With a model number I can give you an average price. Chances are it will run anywhere from $30 - $50. Just depends on where you get it. This is also a very easy thing to change!
May 27, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The icemaker is not working
check the supply line to the refrigerator. this will help in troubleshooting. it usually hooks up near the bottom at a solenoid valve. If you have water at the bottom and not the top, replace the valve. It is a simple project
Nov 26, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker sequence is out of syncronization
I believe your ice maker is the reason for the problem. If you have a model number it is possible that parts are avaiable. Sometimes the complete ice maker will need to be replaced because the controls are electronic in some model ice makers. Could you send the model number of your Whirlpool Refrigerator? Thanks, Sea Breeze
Aug 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have water to the water line and it comes out the water dispenser, but I get no Ice from the maker and it doesn't make any ice at all. this is a hot point refrigerator freezer with the ice maker on the...
Hi: No.1 it takes 24 to 72 hours for the machine to make ice. No. 2, If the freezer is not at zero degrees it will not make ice. I'm not talking frozen but zero F. Ice cream will be rock hard. These icemakers are thermally proctected as not to dump unfrozen ice in the tray. I hope this helps, Jeff
Jun 21, 2009 | Refrigerators
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The copper line under my s. b. s. fridge keeps freezing
the line that you ae seeing is the suction line . It sounds like the defrost timer may have gave up the ghost on you and the unit is not going into defrost. Take the model Number and make to the local parts house and have thenm get you a timer. They are real easy to replace and that should take care of the problem.
Jan 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator will not make ice
This is almost always due to a faulty shutoff valve. The valve is at the back, where the water line connects to the refrigerator. Turn off the water supply, remove the water line with a wrench. You should be able to take out the valve with a few screws and by removing one or two wiring clips and the plastic line on the other side leading to the fridge. A new one costs about $60 - $80 at a appliance parts store. Bring the old one with you, and the refrig. model number, and make sure the new one looks the same as the old.
The problem stems from the valve continuing to leak a bit of water to the icemaker after it fills the tray and shuts off. This trickle of water freezes and blocks the line, so matter how many times you defrost it, it will just happen again.
Jan 14, 2009 | Whirlpool Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
