Ok so i went into disk management and it was already marked as active, yet still unable to access it
  • Jack
    Jack Aug 23, 2010
    i did not see your original posting i can guess that you have a secondary drive and you cant access the drive is this drive new or you use it before
  • sons_of_anub Aug 23, 2010
    correct, i didnt know how to post a follow up question, yes i have an external HD...here is my original post...http://www.fixya.com/ThreadAsker.aspx?th...
  • 45 Answers
You must add or change a drive letter to the drive. Right click in Disk management.
Posted on Aug 23, 2010
    i had already changed the drive letter from F: to K:, also when i run chkdsk K: in cmd, i get that most(if not all) files are unreadable, and upon restart it asks me to run disk check at BIOS, does that mean that the info on the drive is corrupt? because i read elsewhere that it has to do with the jumpers, right now it is set to CS; it also has MASTER/SLAVE/an unmarked one/then PM2 in that order.
  • kenguruguru Aug 23, 2010
    Is it important data on the disk?
    If not you can normally repartition, format and add a drive letter to it.
    If you have data on it it looks like a MFT problem (Master File Table)
    Try this: Restart your machine and go into BIOS. Find your disk and select LBA and restart. Maybe your files will show up in Explorer.
Windows Media Player has stopped playing/burning?
try to read first Windows Help and support.
search for Burn a CD or DVD in Windows Media Player
or look link Microsoft Community Microsoft Windows
Dec 19, 2014 | Microsoft Windows Media Player
No assigned letter
Dear Bev,
Disk zero would be your internal drive and you do not want to be messing about with that.
Right click on My Computer
Select manage
Select Disk Management
Identify the (correct) disk
Right click on this disk and select Mark Partition as Active
If already active select the option to assign a drive letter.
If you are saying you have already done this and these options are blanked out then it looks like your hard drive "box" is being recognised but not the drive itself which may be a drive problem. If they supplied a CD, please run it to see if it installs any drivers.
Nov 14, 2013 | Computers & Internet
Unable to format the 2GB
STEP 1 - Connect your flash drive, MP3 player (in MSC mode), memory card or card reader to the PC
STEP 2 - Open Disk Management
Windows 7 or Vista
Click Start, right-click on Computer and select Manage.
Windows XP
Click Start > My Computer > Manage.
Under Storage, click Disk Management on the left pane.
Windows 7 or Vista
Windows XP
STEP 3 - Format the device / MP3 player
1. Right-click on the drive / device you want to format then select Format.
2. Occasionally, a warning may come out concerning active partition, click Yes.
3. You can leave the formatting options such as the Volume label and File system to default.
4. Click OK to format.
Nov 24, 2012 | SanDisk 2GB microSD Memory Card
I have a Serial ATA HARD DRIVE, 80GB When connect to my Laptop through USB connection, it is recognized, installed and say it is ready to be used. I cannot see it displayed in My Computer
try going to disk management and check if it was recognized there and might just need to mark the partition as active....how to get there simply open the RUN command and type in compmgmt.msc then hit ok you should see the computer management window then look for disk management there...
Jul 05, 2011 | Computers & Internet
How to format maxtor 80gb hard drive
Insert the drive into the bay and connect power and ribbon cable.
Go to Start > Control Panel > Administrative Tools >
Computer Management > Storage > Disk Management
Right click on the drive, click Mark Partition as Active then Format.
In this day and age, it's always best to format to NTFS file system.
Nov 06, 2009 | Maxtor Hard Drive
Dell inspirion 530 Black sreen at boot up with blinking cursor
HI there.
Hit F12 - enter diagnostics - then run them
It should from memory run a test called 'DST' which stands for disk short test. If this passes OK your disk is 99% ok. If OK then (my guess is you have WinXP) boot the XP install disk and attemp to install Windows. If the installer detects a version of windows already on the disk it will ask you "if you wish to repair the copy already installed"
If it does hit yes - ( you wont lose your data however I hope you have backed up)
After it has finished your done.
Hope this helps you out.....Mark
Aug 28, 2009 | Dell InspironTM 1501 Notebook
6t04 adapter, yellow triangle and exclamation mark,
Ok, first thing you need to do is, see if you network adapter is enabled ... You can do this in the Device manager. If there even is an adapter ... If there isn't download the drivers for your Ethernet card, put them on a mem stick and just install them on your Vista machine ...
Mar 18, 2009 | Packard Bell 1580509280 Network Adapter
System logging off as soon as i starts it. Please see details..
Looks like you've tried a lot. Try this stuff.
1) Try F11 instead.
2) Dunno. Corruption?
3) chkdsk /f
4) Microsoft EULAs are much less crackable than their software, according to BitTorrent.
Feb 12, 2009 | HP Computers & Internet
I just bought a Nextar MP3 model number MA933A. I have installed the drivers, but can't get my computer to recognize the player and I don't know how to get my itunes songs onto the MP3.
  • Go to Start Menu, Control Panel, Performance and maintenance, Administrative Tools, Computer Management.
  • Double Click Computer Management-> Under Storage, Click Disk Management.
  • Click the box containing your Removable Disk (Healthy), Right click and Click Mark Partition as Active if (enabled) or click Format... Check the box Perform a Quick Format then Click OK.
  • Reboot your computer.
Dec 27, 2008 | Nextar MA933A MP3 Player
Unable to access new hard drive
Try looking for the drive in the "Disk Management". Right click on "My Computer" or "Computer" and select "Manage" then select the "Disk Management" item.
If you can see the drive, but there is no drive letter assigned, you may need to format it for your operating system or create an accessible partition on the drive. You can access all these options by right clicking on the drive from the "disk management" screen that you should be on.
Good Luck!
Nov 13, 2007 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
