Question about Xerox Phaser 8200 Laser Printer
Paper jambs as it goes from the paper tray into the slot where the paper is fed in through the manual feeder. The printer will print on paper manually fed in through the manual feeder but cannot set up software to use this slot. Printer says that I have inserted the wrong size paper and insists on using the paper tray.
  • wb5vgn May 07, 2008
    Something broke in the printer. It cannot even print a report without a jamb.
  • 3,037 Answers
Whatever program you are printing from has the paper type set up as the size you want it correct.
What you can do is try and reset the printer by leaving it unplugged for an hour and see if that helps. If it doesn't we can try a few other things, but try this first and then get back to me on how it goes.
thanks
Posted on May 04, 2008
  • Benjamin Patri
    Benjamin Patri May 06, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    By something broke, do you mean you found a broken piece or hear something rattling when you shake it?
    Have you tried cleaning off the rollers that grab the paper?
  • Xerox Master
  • 13,433 Answers
Hello wb5vgn
I beleave you have to configure it in the printer to use the other tray in the settings, if this model has a lcd screen and controls.
If you can most me the exact model of your printer I can find you the manual and see how its done.
If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
  • 655 Answers
Check out if there is any piece of paper got stuck, that might cause this type of problem.
  • Iqbal Husain
    Iqbal Husain May 04, 2008
    Friend here is a link for manual. (Abrobat reader is required.).
    Please see page 18 in the manual.
    Thanks
    Iqbal
  • Iqbal Husain
    Iqbal Husain May 07, 2008
    If you find something broken in the printer:
    • then the best solution to this will be to have a visit at your printer service centre for repairing/servicing.
    Thanks n Good Luck
    Iqbal
HP designjet 130NR won't pick up paper from the tray.
paper tray lift clutch failure is likely the cause - common for this machine - repair with new feeder assy ordered whole from HP/ or Partsurfer
Jan 28, 2014 | HP DesignJet 130NR InkJet Printer
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
PAPER FEEDER NOT WORKING OR THE WAY OF FEEDING IS WRONG
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Nov 25, 2011 | Canon Office Equipment & Supplies
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
A small screw dropped into the top feeder of my Canon Pixma printer. I have tried holding the printer upside down and shaking it, nothing comes out. When I try printing from the top feeder, the paper jambs...
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 06, 2010 | Lexmark X4650 InkJet Printer
Paper feed not straight, causing jambing
You need to look inside the slot where the paper is loaded with a flashlight and small mirror. Usually the only reason that happens is when something has fallen in where the paper goes. I usually find pins, paper clips, candy wrappers, or jewelry dropped inside. A paper clip straightened out can help remove the objects.
Oct 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I am trying to align my ink carts. I have printed
This happens on several All-in-One devices, including Brothers. Your device is not sensing the document in the ADF ( Automatic Document Feeder ). These, like the others, are mechanical vs. an optical sensor. Look in where the paper is fed into the ADF, and make sure that the mechanical arm is showing. It would be a small plastic piece, usually near the middle, to accomodate smaller scans and would be 90 degrees or perpendicular to the scan tray and "hanging" off of the top, sometimes the bottom, but typically the top. If you see something that closely resembles the description stop. Home Use All-in-One ADFs are notorious for looking like they have a big mouth, but actually can only handle about 10 sheets at a time, max. If your paper count is only the one, calibration page, pull the page back and reinsert it, pushing slighly harder until the paper starts to bow. If you have a LCD menu screen, watch to see if it acknowledges the paper being in there. On the Brothers, the text says ADF ready, when the paper is sensed from properly being insterted, deep enough. On all printers, including all-in-ones, the Mfgr accounts for paper jambs in the print path by making doors that you can pull out jambed or crumpled papers. Open each of those doors, verify that there is no jambed page somewhere, then reclose the door, snapping it closed firmly. Rerun your calibration page. This should resolve your issue ? TIP: If you are having trouble getting the paper to pickup and transfer through the entire paper path, get a clean cloth and some standard isopropyl alcohol. Wipe down all of the rubber wheels, 360 deg on each one. Slightly time consuming, but only need to do it annually or when the issues arises 'paper slippage'. This process restores the "grip" back into the rollers without destroying the rubber. If you see a lot of 'paper dust', buy a can of "compressed air" to blow out the dust. Typical problem since paper is made of compressed fibers. Good luck. I would appreciate your rating of my answers.
Toby White-Beebe
Dell Certified Lead Systems Expert
Aug 28, 2009 | HP Office Equipment & Supplies
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Roller Cleaning is completed.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
I have a brother copy/fax/print MFC 5860. i am unable to print. no paper jam..the screen reads: no paper fed #2. reload paper, then press start. i have paper in both paper trays and have autoselect...
lower paper feeder is out of position. you have to open the printer and get to the lower paper tray feeder. push the plastic gear wheel and axe into position again.
May 15, 2008 | Brother Office Equipment & Supplies
Xerox Phaser 8200 Laser Printer Logo
62 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
