Question about Crosley Dryers
My dryer was working fine but used alot today it got extremely hot and quit working at the cool down portion ,I checked the lint trap and it was beyond full- loaded is there a common fix for this
  • Crosley Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Iget alot of lint in my laundry cant find lint
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open). All dryers have a lint trap (building codes probably even require it).
May 15, 2010 | Amana NAV2335A Top Load Washer
Smelled like something burning, then quit working
clean lint trap out more often after every load and try to vacumn inside lint trap lint tends to slip down below the trap and yes it will ignite from time to time My gas dryer did it once and yours it smoked and stunk but because I was home it never went furtherif you open bottom front panel if your machine has one you can get a lot of old lint cleaned out there as well...and most dryers post in their manuals the risk of lint fires
Dec 18, 2009 | Dryers
We have modelPYE2300AYW it quit drying. The lint
it has two different high limit switches that need to be replaced . one in the front and one in the rear. this happened to mine and it cost about $20.00 to fix
Oct 21, 2009 | Maytag PYE2300AY Electric Dryer
Once we put a load of wet clothes in the dryer after about 3 minutes the dryer shuts off. The top of the dryer becomes extremely hot. We open the dryer door and let it cool down and then the dryer starts...
Wet clothing doesn't allow proper ventilation while tumbling clothes. This in turn causes electrical shorts: steam in chamber and reduces airflow. Reduced airflow will will cause the drier to shut off on an over temperature condition. Moral of story, spin clothes as dry as you can and when tumbling, make sure you have good ventilation to get best results.
Sep 26, 2009 | Dryers
Dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top...
More than likely, the motor centrifugal switch is stuck. You should be able to turn off the element with the timer control switch. If the timer switch is on and the dryer is not running, the element should be off, unless the motor contact is stuck closed. You will have to get to the motor and 'un stick' the contact.Its a bit tricky, you may need help.
Jul 21, 2009 | Kenmore 62802 Electric Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Longest 6 minutes ever
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Apr 03, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
