Question about Panasonic Microwave Ovens
Turned on the microwave as usual. It started, then after one second when dead. I thought it might be a house fuse but all the other appliances work and I checked anyway. Just went from working to dead! Any solution or just buy a new one? its about a year or two old, a high power 1350W inverter.
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 23, 2010
Microwave won't start
Check the fuse usually a 25 amp appliance fuse behind key pad
Mar 18, 2014 | Whirlpool MT2110SJQ 1100 Watts Microwave...
GE spacemaker XL microwave oven blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | GE Profile Spacemaker XL 1800 36 in....
My microwave quit working.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches or on a small filter board in the back where the power cord comes in.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron, or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed or virtually zero ohms.
Also, the hood thermostat usually has thinner wires that are not black or white, like the other thermostats' wires.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Jan 10, 2010 | Emerson Microwave Ovens
Dead microwave!
Hi Kevin
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If still you are unable to diagnose the issue then it is recommended to call a local repair center for this to get fixed as Microwave usually have high voltage even when it is turned off.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 24, 2009 | Kenmore 63672 Convection/Microwave Oven
Neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Neff H7871 Convection/Microwave Oven
I have a hotpoint microwave MWHZ33 (combination grill/microwave/) When you press the buttom to "microwave food" within a few seconds the 8amp fuse blows in the internal power supply. Any...
GE / Hotpoint models usually have about a 2-second delay between the time you hit Start and the time the high voltage section turns on.
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 30, 2008 | Hotpoint Microwave Ovens
Microwave fuse mystery
AHD_NZ
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Guest
May 28, 2008 | Microwave Ovens
Microwave just quit working i thought maybe it was a breaker but it wasn't
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 20, 2008 | Frigidaire GLMV168K Microwave Oven
Microwave keeps blowing fuse
Here are some links with info on part testing:
Please write back with your brand and model number if you need further help.
Jan 03, 2008 | Microwave Ovens
MICROWAVE
First of all, it Roper may honor the warranty even though you're not the original owner. I'd contact them first: http://www.roperappliances.com/support/
If they won't cover it, here are some tips:
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
This last issue is what I suspect in your case.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We appreciate your thoughtful rating of our answer.
Nov 09, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
