Question about Troy Garden
I have a Troy Bilt TB90BC. It starts fine but doesn't want to run unless the choke is on or the engine is revved all the way. Any thoughts?
  • Troy Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Aug 23, 2010
Troy bilt bronco
Check flywheel alignment key for partial shearing causing a slight out of time situation. .
May 27, 2014 | Troy bilt Super Bronco Tiller 208cc
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Gas dripping out of air intake on troy bilt trimmer TB525EC
The diaghrams in the carb could be starting to stiffen up holding the needle open. Does it start with no choke when cold? Rebuild the carb to replace stiff diaghrams
Oct 24, 2012 | Troy-Bilt 4 Cycle Straight Shaft String...
I have a troy bilt pony with a 6hp Tecumseh engine. It's difficult to start and when I get it started I have to leave the choke on or it will die. Also it doesn't run as it should. I drained the...
I recommend cleaning the filter with gasoline if its foam or replacing it if its paper. If this doesn't fix the problem you should remove the carburetor (in between the air filter box and the engine) and cleaning it thoroughly with carb cleaner from your local parts store.
Jun 17, 2011 | Troy-Bilt Pony Garden Tiller
I have a Troy-Bilt TB90BC string trimmer. The engine starts & runs fine but the trimmer head runs slowly and stops under light loads. I removed the lower shaft & confirmed the cable connection is...
it sounds like the clutch may have oil on the shoes or oil in the clutch drum if it has a clutch or the clutch is binding and not fully locking up.
May 02, 2010 | Garden
Troy bilt tiller
either the carb needs cleaned or theres a vacuum leak
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Only runs on full choke
You can try to open the high speed jet a little on the carburetor. This may fix the problem.
If you need more help, post a comment and I will get back to you
Tim
Garden Logo
289 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
