Question about Acer X241Wsd Monitor
My monitor X241W flashes the ON/OFF LED, and nothing comes out on the screen. I changed all the filters,measured all fuses, transistors and MOSFET but everything seems to be all right. What else can it be? It's a shame throw it away 'cause is huge.
  • jorge_alejan Aug 30, 2010
    After my detailed revision on my power board,and all the components looked fine,I kept cheking on the voltages in each one of them,right in the middle of the board,the voltages cut off. and it was nothing else than the transformer for 5,12 and 19 volts. I took it out and measured it getting as result that the secondary is shorted. Big trouble,because even when I found the problem it's almost imposible to find that transformer.
  • 11,361 Answers
It may be in the safety shutdown mode if it sensing too much current draw. No short circuits in the inverter board. Plug it ino the wall out let and do not activate the power switch so the power supply will be running without having to power up the inverter board, if the 24vd is OK in the power supply then you may jave problem in the inverter board. How does the DC voltage on the secondary power supply side? Bad caps can look normal but it can have high ESR (Equivalent Series Resistance) which is a no no for switching power supply. Post back with more info. So far I cannot locate free service manual download for this model.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 23, 2010
Lcd benq t705 power button not working
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Nov 24, 2013 | BenQ T705 17" LCD Monitor
Flashing monitor benq 2420
Oct 02, 2013 | BenQ Computers & Internet
Dell E173FP power led orange/flashing failure returns
First, you can get the service manual here: http://elektrotanya.com/
If the transistors failed again, yes the 0.22uf (part of tuned circuits for the inverter transformer oscillator circuits) changed value, the frequency will be off and causes over heat on the transistors due to too much current draw, You can also have bad inverter transformer, you can check the DC Ohm value but if it has one short turn, it will not show up on DC Ohm test, you have to use ringer testing (I use SENCORE LC75).
Mar 29, 2010 | Dell E173FP 17" LCD Monitor
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
Blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Jun 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Benq 737s monitor black screen
BenQ LCDs are known for poor solder connections causing the inverter driver transistors to short.
Result is no backlight.
Monitor Mike
Jan 03, 2009 | BenQ FP737S-D 17" LCD Monitor
Please help me.
checked the horizontal output,a big transistor near the flyback trnsformer, if it is shorted replace it,,,,
Feb 13, 2008 | Sampo AlphaScan 411 Monitor
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
Acer X241Wsd Monitor Logo
253 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
