Question about Garden
I have same problem with Chicago Electric # 47761 electric pressure washer as Aug 10 2010 writer had w/ Karcher 2500. Runs briefly then stops. Pressure is trapped in hose. I cleaned hose disassembled & greased valve in handle. No improvement. Problem appears to be premature wear of trigger cam in handle - both are plastic. Valve body is rigid nylon. Any thoughts??
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
Posted on May 23, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
  • 10865 Answers
SOURCE: Karcher Pressure washer surging/pulsing
here is a troubleshooting link for Karcher products
http://www.the-power-washer-advisor.com/electric-pressure-washer-troubleshooting.html
Posted on May 31, 2009
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
Karcher 1600 pressure washer will not get power. It was working then stopped getting power. It is not that old.
ok im a technician... cheak d power swtich. i think most of karcher power knob switch they got a error problem.
May 30, 2011 | Karcher K2.26 Electric Power Washer
My Karcher 2.99 starts and stops, (pulses) when th...
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
Karcher k 3.99 does not pause correct
Is there a water leaking from the bottom ? If so then there maybe is a small crack in the Pump Plastic Manifold Housing. A New Manifold Complete Replacement is approx. $61.03 from Karcher, if you are mechanically inclined.
Mar 16, 2010 | Karcher K 5.85 M Electric Pressure Washer
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher k3.48 pressure washer appears to be seized up?
if the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Jun 01, 2009 | Karcher PSI Electric Pressure Washer
Karcher k7.91 pressure washer /loss of pressure
if the motor will not turn on ,thers a problem with the current excess switch , which is situated under the main power on of swith hi needs to be replced
May 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
324 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
