Question about Maytag MSD2454G Side by Side Refrigerator
Condenser is to hot to touch And now both the freezer and refrigator is blowing warm air
  • Maytag Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 23, 2010
7 year old refridgerator not getting cold enough. Thawing in freezer. Should the condenser be hot/warm to the touch? Is there a re-set?
The condersor coil will be very warm to hot..not so much so it will burn you, yet very warm..the things that will make it very overly warm is if its clogged with dust or the condenser fan motor isnt running all the time the compressor is on. But it will normally be warm all the time the compressor is running..that heat is whats being removed from inside (the way refrigs. work is they remove the heat so when the heat is gone only cold is left)
GENE
Sep 04, 2011 | Kenmore 56983 Side by Side Refrigerator
Freezer ice cream soft, refrigerator cool but warming up, the wall separating freezer/refrig is hot to touch. Note: a transformer on the power pole blew and there was a power outage. Could a surge have...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 31, 2011 | Refrigerators
Side by Side GE Refrig/Freezer is blowing hot air out of the bottom - is this normal?
If your refrig is 10 yrs old or les , then yes , this is normal . It pulls air in from the back over the condensor coils then compressor and out thru the front . The refrig should be 3-4 inches from the wall so it can pull fresh air thru . If any closer , the hotter the air will be causing the coils and compressor to be hotter than designed for therefore causing less life for the refrig . The WARM air is good meaning the refrig is cooling properly .
Jul 18, 2010 | GE Refrigerators
Inside refrigerator strip between the freezer and refrigerator
The condenser fan motor at the back near the compressor is either dirty or not running at proper speeds. Clean the coils for air flow over compressor and if the fan is not running replace the fan.
Jul 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore refrigerator isn't getting cold enough
SHORT OF GAS,OR WEAK COMPRESSOR. NEED ENGINEER.
Mar 09, 2010 | Refrigerators
Freezer/Refigerator not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
oiopi
May 09, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Amana ABB2224DES Stainless Steel Bottom Refrigerator is warm however the freezer works fine. How do I solve this problem? I vacuumed the coil and renoved most of the dust accumulation. Is there a way...
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, make sure u didnt turn up freezer control cutting air supply to refrigertor side should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
Sep 02, 2007 | Amana ABB2224DES Stainless Steel Bottom...
Maytag MSD2454G Side by Side Refrigerator Logo
59 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
