Question about Acer AL1916W 19" LCD Monitor
My monitor is split screen and everything is backwards on left side of screen How can I fix this
  • 11,361 Answers
Vrify that it is not the PC video card problem by trying on another PC first, otherwise it can be the video processor problem or the T-CON board (part of the LCD panel which the board cannot be replaced). Post back what you find.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 23, 2010
Testimonial: "Thank-you, your answer was very helpful and yes, I do need a new monitor. "
Acer gd235hz 23.6 lcd monitor is blank on the right side only the left side of the screen shows pictures
It sounds like the monitor is broken. You should probably just buy a new one. If you haven't already, try checking the cable connections to the pc. Outside of that, there's not much you can do. Hopefully you still have a warranty on it and cant have it fixed.
Oct 18, 2017 | Acer Gd235hz 23.6" Lcd Monitor - Black
Monitor problems
Have you tried to reset all your setting to default through your monitor? Sounds like an overscan issue, like the monitor is trying to display video past the actual size of the monitor so it raps around itself. You could try and lower the screen resolution on your desktop and see if it goes away as well...
Nov 04, 2013 | Computers & Internet
Subtle Two Toned Split Screen Color Difference.I think I hit some button by accident. Monitor is great but now I have a split screen where the left hand side of the screen has a lighter tint than the right...
Hi. I have got the same problem, and it was very easy to solve. Monitor was LG. The problem was not in the system, it was in the monitor. I just clicked the buttons on the monitor, it was on the wrong setting that divides monitor in two colors, so if it happens to you, try checking your monitor settings, mine was set to "demonstration", half was lighter than the other one, just set it to usual or user. Keep in mind the settings are on the monitor itself, not in the windows (buttons on the monitor itself) Good luck.
May 10, 2012 | LG 22" FLATRON LCD Monitor
Permanent split screen down middle by black line
The GPU has overheated that is what causing this problem.
You will need to stop the heat build up and get it repaired - you can even do this with a good guide or send it in.
Nov 01, 2009 | Microsoft Xbox 360 Console
Can i make the display split-screen full again ?
dbdbf85.gifyou should see a symbol similar to this in your I-drive it moves the nav. screen to the side of the display.Usually if you press it, it will toggle between different displays. If you look into your owners manual there should be one book that is completely dedicated to the navigation system. good luck
May 02, 2009 | Car Audio & Video
NOTEBOOK PANEL FITTING
It fixed itself. I shut down computer and let sit overnight. On next reboot everything was back to normal!!!
Sep 23, 2008 | Acer Computers & Internet
Gx270Screen splits up
Check your video card settings, it sounds as though the setting is set for two displays.
Good Luck.
Jun 10, 2008 | Dell OptiPlex GX270 PC Desktop
How do you split the screen to have google on left side and home page to right? Thanks
Maybe you're talking about the Dula Monitor. You need to buy a video card that has two video port. Either two VGA ports, DVI ports, vice versa and so on. Plug the two monitors to the two video ports. That's it.
Jun 02, 2008 | Computers & Internet
Split screen in two halves
wierd problem.
Smack the monitor around a little to see if there are any bad connections.
Tap it on the sides and the top. If the picture changes, you will have to either check and repair the board or take the unit in for service.
If it doesn't, then it sounds like there may be a problem in the horizontal sync circuit of the monitor. Since it is intermittent, it may be tough to solve.
Be sure to try it on another computer to make sure the fault is the monitor.
Mar 27, 2008 | ViewSonic E55 15" CRT Monitor
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
