My JVC HD-70FH96 television has shut down the HDMI input due sunlight shinning through the window behind the TV. The fix of press sleep timer set to zero, then press together display and video status button on the remote with the tv catv setting on tv, should bring up a service menu with 3 choices. 1. Video Adjustment, 2 Self Check, 3. XXXXXXX. Slect 2 for self check. shut down TV let the cooling fan run until timed out. Unplug TV for 30 sec. Plug TV back in, turn TV back on, Hdmi ports are operational. The above is not working. I get the sleep timer @ zero, but when I try the next step no joy. I get nothing. This happened once before last year, and someone came up with a fix that involved reseting the lamp timer I think. I thought I wrote that proceedure down, but I guess not. Any Idea or help?
  • 5,138 Answers
Chances are you now bigger problem then just reseting program have you Looked on your power supply board for bad capacitors they will be swollen ,vented or puffed up on Top.
Posted on Aug 23, 2010
My hdmi port in the back of the tv does not work..i have never used this before and we bought a ps3 when i hook it up all i get is a green screen but i know it is not my ps3 or cable because they both work...
1a) make sure the two slide switches on the top of your remote are set
to TV and VCR (both to the left).
1b) Press SLEEP TIMER and make sure it is set to "0" minutes. (Only on
screen for 2-3 seconds)
2) While "0 minutes" is being displayed on the screen, press DISPLAY and
VIDEO STATUS at the same time. This will pull up a service menu on
the screen.
3) Press the option # 2 (SELF CHECK) on the service menu
4) Turn the TV off and allow the set to run its normal cool down
process.
5) Turn the TV back on and set the TV back to DIGITAL IN mode by
pressing on the INPUT button.
Jan 09, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
HOW DO RESET THE HDMI INPUT? JVC , HD61Z456.
Set the remote to "TV" and 'VCR". Press the sleep timer once and "0 Minutes" will show up on the screen. Afterward, press and hold the "Display" and "Video Status" buttons simultaneously and then let go. A menu will show up on the screen, then press "#2" on the key pad. A new menu will show up on the screen, then shut the power off. I was told it could take up to 3 times for this to work. Hope this helps.
Jun 11, 2010 | JVC HD-61Z456 Television
JVC 40 inch LCD digital inputs (1 and 2) no longer works. Standard video and component cable inputs work, but not HDMI. Please help
This TV has a sensor that deactivates the inputs when light is sensed. perform this procedure to correct it:
1. press "Sleep" button on the remote
2. while "Sleep timer 0" is showing, simultanuously press "display" and "video" button on the remote
3. you should be in the Service menu of the TV....if not you should do the steps again
4. select "self check" from the displayed options.
5. when the "self check" menu is displayed, Power off the TV.
6. unplug and replug the TV.
7. Check the digital input.
if the input never worked for you, it is possible that you have the DVD/Bluray/whatever set up incorrectly. I don't think this TV accepts 1080P resolution so make sure it is set to 1080i or lower
Jun 23, 2009 | JVC LT-40X776 40 in. LCD HDTV
My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
Jan 09, 2009 | JVC HD-61G787 61" Television
JVC HD-70FH96 both HDMI problems
Have you been using a flashlight behind the TV. These TV's have a sensor that shuts off the unit when the rear cover is removed (by sensing light). You may have tripped this. I think you can fix this in the service menu somehow but I can't remember.
Oct 10, 2008 | JVC HD-70FH96 70" Rear Projection HDTV
JVC HD-52G786 Service Mode
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
Jun 18, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Turns off on its own like it was in sleep mode
Probable bad connect / bad caps in power supply.......
Fixable .....usually about $100.00 in the shop..............T.
Dec 07, 2007 | JVC AV-27D305 27" TV
HDMI input failure
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
simultaneously.
This should work.
Oct 06, 2007 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
