posted by Haniefbagus on May 04, 2008
Epox 5p945 not detect Core 2 Duo E4500 micro code.How....
Comment by Haniefbagus, posted on May 06, 2008
Thanks for yuor solution.
Best Solution
posted on May 04, 2008
Actually it does.
They should work together. Are you sure you have it seated properly? Are you getting any beeps?? Using correct memory modules???
Tested HERE
Tested HERE
Rating Locked! (?) Haniefbagus has rated this solution as Helpful
Solution #2
This mainboard des not support Core 2 Duo, only P4, celeron and dual core pentium-D, mainboard page spec.:http://www.epox.com/USA/product.asp?ID=EP-5P945-3
Comment by shapirit, posted on May 06, 2008
Hey!,
there are 5 models of 5p954 why did you choose the pro?
one more thing, a problem with the microcode means that the bios do not support the cpu, eather update the bios or replace cpu
Rating Locked! (?) Haniefbagus has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for EPoX EP-5P945C GLI Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
