Question about LG DLE2514 Electric Dryer
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
  • LG Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 23, 2010
Lg gas dryer not drying, heat not kicking on.
Take it apart and clean the inside. wipe off your sensors and thermostats. also clean your vents. if that doesn't fix it , check parts with ohms meter. good luck
Dec 01, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Our Dryer runs but is not expelling heat. How can we fix this issue? The dryer only blows cold air. Thank you
check the vent line if clogged it will cause the sensors to trip off way too soon . that will not allow it too make any heat. check up inside the dryer as well if the vent is way clogged with lint the dryer will too. the vent should be cleaned twice a year
Aug 07, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm DLE 5977W will tumble but won't heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 03, 2011 | LG DLE5977 Electric Dryer
Gas LG tromm dryer that takes 2-3 cycles to dry usually and then yesterday no heat at all. I have cleaned all of the lint out both front and back. everything comes on and tumbles but no heat. I am...
heatman101
Aug 01, 2011 | Dryers
My dryer doesn't heat.. How can I fix thus
check out this electric no heat tip...
heatman101
Dec 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer not heating
heatman101
My LG tromm dryer wont heat and i don't know how ignite the pilot
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLE2514 Electric Dryer Logo
222 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
