Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Poulan 33cc Weedeater 3 mo old will not idle, dies during acceleration
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Aug 23, 2010
Spark plug gap for poulan weedeater
Go to the following site where you may well find parts needed
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Jun 10, 2014 | Poulan Pro Ppb330 33cc Gas Line Grass Lawn...
Did not get an owners manual with my 33cc gastrimmer need to know the gas oil mixture .
40:1 = 3.2 oz of 2 stroke oil for every gallon of gas
Link to manual is below http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
May 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a Poulan Pro PP133 33cc 2 stroke weed eater. It starts but when you give it full throttle it dies. It will Idol but will not accelerate to full power, then it dies if you don't let off the trigger....
check spark arrester in muffller where exhaust comes out there is a screen either under a plate with 3 screws or a round tube that u can pull out with pliers somtimes they clogg with carbon and wont let exhaust out. enuogh at idle but backs up after that hope this helps
Aug 12, 2010 | Garden
Johndeere c1200 weedeater
Clean air filter and check fuel lines for trash.If that isnt the problem your carb may have trash in it.Thanks for asking and I hope it helps.
Jul 16, 2010 | Garden
Need the know the correct H and L settings for our Poulan P3314 14 in. Gas Chainsaw - 33CC. The chainsaw will not idle.
There are no hard and fast settings.
The initial starting point "H" and "L" are 1.5 turns CCW from lightly seated.
The"T" adjustment enters here too (idle speed) and there is initial setting without a tach, depending on age may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Fresh mix of fuel. Put ALL of the old mix in any 4 cycle and start new. I suggest 50:1 regardless of what your manual says. This is the best performance adjustment I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 09, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Prolink PPB 330 starts easy, bogs down on high speed
poulan ppb 330 33cc trimmer .idles but no high speed power.
my solution was to remove postage size screen on muffler known as spark arrester and clean. runs great know !
Sep 04, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
294 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
