Question about ASUS Computers & Internet
Hi I just moved my work computer to my home office and when I turned it on, my ASUS monitor just says out of range. It worked fine before on the same computer. Can you help me? Thanks.
  • 11,361 Answers
Asus manuals
Go here, select your OS, and download/run the latest "Utilities ATKACPI" driver and "Keyboard Device Filter Utility". See if that helps. Good luck. http://support.asus.com/Download.aspx?SLanguage=en&m=X102BA&p=3&s=533
Jul 20, 2014 | ASUS X102BA-BH41T 10.1" Touchscreen Laptop...
My Asus VK191S monitor comes up with the following error "out of range". How do i solve this
You will need to change the screen resolution of your computer. It means that the monitor cant handle that screen resolution. If your are unable to access your computer because of this my may have to hook it up to a monitor that can handle it then go turn the resolution all the resolution. Then hook up the Asus monitor and work your way up. till its at the highest resolution without saying "out of range" you do this by right clicking on a blank space on the desktop and going to properties or personalize then display settings or a similar tab or category :) hope this helps
Dec 27, 2010 | ASUS LCD Monitor
Out of range error
Out of range message means that the video resolution signal the monitor is receiving is not supported by the monitor. How do you hook up the DVD player to this monitor since it does not have composite ot component video inputs?
Spec: http://techwiki.hardwarecanucks.com/product/1NjEyNzUxMzgzMzE/ASUS-VW192T/#spec
http://s807.photobucket.com/home/budm/allalbums
Jun 28, 2010 | ASUS VW192T Monitor
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
"Input Not Supported"
what type o fmonitor are you using??
try to reset the monitor back to 800X600 or 1280x720, 60HZ or max. 72Hz
Oct 28, 2008 | Acer AL2016W 20" LCD Monitor
Ibm thinkvision l170 monitor
Hi! Tammy,
It's seems your new pc resolution settings, set to high...
Hook up to another monitor and go to settings to correct your
resolution to 1280x768 or less. That will fixed your problems.
Good lucks!
Aug 07, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor
Does it occassionally turn on or does not turn on at all? I advise that you try a hard-reset(disconnect completely from power supply for about 2 hours). If it doesn't work then you will have to get a replacement inverter board.Let me know how it turns up so that i can assist you further. Thanks for using Fixya.
May 22, 2008 | ASUS VW193T Monitor
NO SIGNAL INPUT - message
Hi Rick,
Most common cause of this error is when the video signal cables are knocked off rendering the connection from the monitor to the CPU loose. Turn off the PC and secure all connections. Have you had your computer moved or repaired where you need to remove connections? Some PCs have more than one video cards (video output) and you may have connected it in the wrong video port. You can isolate the problem further by connecting your CPU to a known working monitor (office, freind's, neighbor, 2nd home PC). The other way is to isolate the problem is to connect your problematic monitor to a known working PC and see if video will be displayed. If video is present, your CPU's video card has gone bad or the contacts are not seated properly in the slot. Best Regards
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Computer locks up
hi jsollars,
the problem is in ur operating system
simple way format ur hard disk & install ur operating system
2nd way:
1) right click in ur desktop click on properties
2)left click on screen saver
3) left click on power it will show u the power schemes just go to home/office desk
4) setting for home/office desk it will shows :
A) turn of monitor--click never
b) turn of harddisk-click never
c)system stand by- click never
5) press ok ...& see ur syatem will not reboot trust me
Mar 10, 2008 | ASUS A7S333 Motherboard
Computers & Internet Logo
163 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
