Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
The problem of my whirlpool not draining o agitating does not seem to be related to the lid switch. It does click when pressed. How do I remove the back to see if something is caught in there? What would I be looking for as potential causes? Finally, at what point do I just scrap it and buy a new washer? Having a repair man come to look at it will cost almost $100. Thanks.
    Champion:
  • 245 Answers
Unless your drain hose is clogged at the end then there are not to many other options than your lid switch. Your water pump could have a sock in it. If you lean the washer on it's back you will see the white or grey pump right at the front cabinet panel. You would have to remove a hose and that can get real messy, so check that last. Good luck.
Posted on Aug 23, 2010
My Whirlpool washing machine will not spin or agitate. The water drains out but does not always spin. If you turn the tank it tightens up and then spins properly.
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 10, 2013 | Washing Machines
Kenmore model 110, stock 22811 fill with water but does not agitate
Try the machine in all the available cycles. If it only agitates in one or more, but not in all cycles, the timer is bad.
Here are a few other things to check: First, make sure the lid switch is working. Generally, if you press down on the switch lever with a small screwdriver or similar tool, and it clicks as you press and release it, it's probably OK. If you hear the motor running, the switch is good. Also if the machine spins, the switch is good.
Next, try to rotate the agitator by hand. If you can, either the ratchet "dogs" are worn and need to be replaced, or the drive splines are worn, and the agitator needs to be replaced.
Next, look under the machine, right in the middle, up front. If you see shavings that look like black rubber, or white plastic, under the motor, The motor coupling has broken or disintegrated, and needs to be replaced.
Finally, if all the above check out OK, the problem is inside the gear case (transmission).
Dec 23, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 70 series top loading washer. Model#11020702990. It is a type 111 It will not drain. It fills, agitates, but does not drain.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20702990&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the drain / spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 05, 2010 | Kenmore 24032\24036 Top Load Washer
Machine agitates but wont drain
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Older models only used the switch during the spin cycle.
May 30, 2010 | Kenmore 22422 Top Load Washer
My kenmore series 80 wont drain it agitates but stops when it is time to drain md#23822100 sr#CM3908062
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23822100&pathTaken=partSearch
I'm assuming that it will neither drain NOR spin.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 19, 2010 | Kenmore Washing Machines
Won't agitate
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92596100&pathTaken=partSearch
If it neither agitates,drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Apr 17, 2010 | Kenmore Washing Machines
Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
Mar 31, 2010 | Whirlpool LTE5243D Top Load Stacked...
Kenmore will not agitate or spin but its not the coupling I checked. Now I have the machine apart and don't know what else it could be. The lid switch makes a clicking sound when pressed could this be the...
agitate nor spin.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Mar 01, 2010 | Kenmore Washing Machines
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
18 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
