My laptop battery hp compaq 2510p is not charging, even with the adapter plugged in. Is the a way to force charge it?
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Aug 23, 2010
When pluged up it say plunged in not charging
It could be that the battery is at it's full charge. Do you have the correct power adapter plugged into the laptop? Is the battery older than 2.5 to 3 years? Deplete the battery by unplugging the power adapter and letting the laptop use up the battery and shutdown. Then plug the adapter back in and power up the laptop. Does it say charging now?
Mar 20, 2015 | HP Compaq 6510b PC Notebook
My Laptop does not turn on anymore... When i insert the ac adapter a the power light flash instantly and gone... but my laptop doesnt charge or turn on...:( i have tried replacing the adapter but...
Take the battery out and run directly from the ac adapter. If it works then the battery is blown up. But if nothing happens and there is no activity then motherboard fuses may have blown or worse the motherboard is faulty. Look for another laptop in that case.
Mar 16, 2015 | HP Compaq 2510p Notebook PC
My Laptop doesnt turn on how do i fix this...help!
Already answered today - take battery out and try.
HP Compaq NC8430: Laptop does not want to charge battery
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Jan 30, 2013 | HP Compaq nc8430 Notebook
Hp 2510p not charging
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Oct 09, 2012 | HP Compaq 2510p Notebook PC
Plug in not charging
this can mean that the battery of your system has failed and needs replacement. you may try to test the battery on another laptop or try another working battery with your laptop. If battery is working on another system, or if another battery has the same result on your laptop, next things to check and try is another charger. If that does not work, the next point of failure would be the dc input connector on the laptop which may also be part of the motherboard and needs to be replaced.
Jun 09, 2012 | HP Compaq 2510p Notebook PC
Compaq 2510p battery not charging
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 25, 2011 | HP Compaq Evo n610c Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
May 21, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
1,198 people viewed this question
David Payne
David Payne
